the bracket that was holding my belt tensioner snapped off the main ac braket..
Anyone tell me if 1991 l98 ac bracket is compatible with 1989 ac bracket... if so whats the going rate for used one?????
Yes! they are compatible. All the other brackets are from '84 - '91. i checked the catalogs Ecklers, Zip, MidAmerica and none carried the A/C Bracket but all the brackets they did carry were for the Alternater, power steering, smog pump and they were from 84 to 91, which will let you know that they are interchagable(oposite side with same equipment 84-91).
Your best bet is going to be to price a new one from the dealer and get a feel for a new one so you can make an educated guess for a used one!Try your local junk yard and POST A THREAD on on the PARTS/WANTED section of the forum. I'm sure someone will have one laying around!!
