Torque specs Throttle body
Old Jun 13, 2006 | 08:31 PM
genoa's Avatar
genoa
8th Gear
Default Torque specs Throttle body
Hi all, I am a new member and posted my first query a couple days ago. I realize I did it a bit wrong!! and not many members would have read it. I need the torque specs for the throttle body bolts to plenum. One GM manual says 18 foot lb. another says 8 - 18 inch pounds. The local GM dealer thinks it is foot pounds as I do-(I got it wrong in my first post)
Any help would be appreciated.
Old Jun 13, 2006 | 08:54 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I don't have a book for your year and mine is not the same so I can't say for sure. But my "quess" would be foot pounds. 8 - 18 inch pounds you can dang near do with your fingers. I'll take a look in my garage and see if one of my books say anytrhing about it.
Old Jun 13, 2006 | 08:58 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You must go with the foot pounds and be careful not to over tighten them. Inch pounds will more than likely leave you with a leak!
Yhanks, matt
Old Jun 13, 2006 | 09:07 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
Ok, I just checked my helm, my chelton <sp?> and my hans manual all tell me for an LT-1 (what I have) it's 19 foot pounds.
Yours should be the same. So go with the 18 foot pounds.
Old Jun 14, 2006 | 08:04 PM
genoa's Avatar
genoa
8th Gear
Default throttle body bolts 18 fp
Thanks for the info. They are torqed and all is ok.
To Torque specs Throttle body
