Changing IAC right now, any help?
Old Aug 28, 2001 | 11:57 PM
Kale's Avatar
Kale
Default Changing IAC right now, any help?
What do I need to do, besides pull it out, and put it in?
Old Aug 29, 2001 | 12:07 AM
Kale's Avatar
Kale
Default Re: Changing IAC right now, any help? (Smash)
How do I get this thing outta here? Do I have to remove the throttle body?
Old Aug 29, 2001 | 12:09 AM
BobMachus's Avatar
BobMachus
I removed, cleaned, and replaced mine a few days ago. I removed the TB to do it. Gave me an opportunity to clean the TB real well and a bit of the plenum.
Bob
Old Aug 29, 2001 | 12:11 AM
Kale's Avatar
Kale
Default Re: Changing IAC right now, any help? (BobMachus)
I guess the TB is coming off. I don't really wanna deal with those coolant hoses,a are they hard to get off, too?
Will I be able to re-use my TB gasket? I dont have a spare.
Old Aug 29, 2001 | 12:20 AM
BobMachus's Avatar
BobMachus
I didn't have much trouble with the hoses and they didn't leak much either. The gasket was in great shape so I had no trouble re-using it. When I went to remove the TB I also noticed one of the 4 bolts holding it on (lower pass. side) was not even threaded in and sticking out about an inch. All in all the whole process was much easier than I anticipated. The coolant hose on the side (as opposed to the one on the front) was toughest to remove. Remove TB/Maf connector, remove TPS plug, remove vacuum lines on side of TB, remove IAC plug, THEN remove hoses. There is another vacuum line under the TB which is easier to remove after bolts are out. Have fun.
Bob
Old Aug 29, 2001 | 12:21 AM
Kale's Avatar
Kale
Thanks, fellow 74U!
To Changing IAC right now, any help?
