Exaust resonance
Old Aug 29, 2001 | 02:00 AM
KJones's Avatar
KJones
Default Exaust resonance
During a moment of sheer brilliance (us old guys have them quite often, the Dr. calls it alzheimers) I gutted the catalytic converter on my 84 while performing considerable engine modification. When I got back on the road I learned that the exhaust resonance between 1300 and 1700 rpm is almost intolerable! It is worst right in the middle of that range. (1500 rpm) I am wondering if any of you have come up with a fix short of replacing the whole damned exhaust system. I am not totally objectionable to putting a cat back on it if that is what it takes…. I have considered a couple of things myself ie. Replacing the old gutted cat with 2 pieces of pipe making it a true dual exhaust. I have also seen a replacement pipe that has a balance pipe between the pipes going from the cat to the mufflers but have no idea if that is effective. I am sure some of you out there have tackled the resonance problem with some measure of success. Any info you can offer will be appreciated!
Ken
Old Aug 29, 2001 | 02:38 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Exaust resonance (KJones)
My FlowMaster cat-back has resonance there too.
I've heard of two possible solutions here on the Forum:
1) cut and weld in a crossover pipe between the two legs of the Y
2) put a reducer in each inside exhaust pipe tip.
Old Aug 29, 2001 | 02:56 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
I placed a pipe right through my hollow cat(s) on my 82 to help reduce noise, this did help.
Old Aug 29, 2001 | 08:08 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
The only way I found to completely eliminate the resonance was to install a Corsa cat-back system. Since you have gutted the cat, I don't know if the Corsa's would help you that much?!?
Old Aug 29, 2001 | 08:33 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Turn the RADIO up!! It will go away :blueangel:
Old Aug 29, 2001 | 09:21 PM
nsimmons's Avatar
nsimmons
I have no cat and holes drilled in my muffler..no real noticible resonance, it still aint loud enough for me
Old Aug 29, 2001 | 10:04 PM
Lord Odin's Avatar
Lord Odin
I have a Corsa catback system and never gutted my cats and I get the same thing. Its so bad, that it actually sounds like a rattle. I'm gonna put it up on the lift later this week to see if anything is loose but I doubt it. Should I even be getting this? Its the worst once the car has heated up.
Old Aug 29, 2001 | 10:13 PM
Muskrat's Avatar
Muskrat
just wear earplugs
Old Aug 29, 2001 | 11:37 PM
Lord Odin's Avatar
Lord Odin
Default Re: Exaust resonance (Muskrat)
Well its one thing to hear the vibration, but its an entirely different situation when you FEEL it vibrate. :cuss
Old Sep 4, 2001 | 04:11 PM
KJones's Avatar
KJones
Default Re: Exaust resonance (65Z01)
First off I would like to thank everyone for their responses to my post on exhaust resonance!
I was particularly interested in the simple fix submitted by 65Z01 in reference to restricting the inboard exhaust tips. I installed plugs in both tips and VOILA..... The resonance is GONE..... Now comes the question, what about economy and performance! I immediately drove to Vegas and back (675 mi. round trip) and got my normal 24-mpg with no apparent diminution in performance.
This makes me willing to try the following:
Replace both mufflers and their attendant dual outlets with a single outlet, low restriction unit.
Add something like an LT1 tip for looks.
Thanks again to everyone for their suggestions… especially the ones on earplugs and turning the radio up!! Lol
Take care and be safe,
Ken
To Exaust resonance
