How hard is it to replace brake pads?
Old Jun 15, 2006 | 11:40 AM
slicked25's Avatar
slicked25
Default How hard is it to replace brake pads?
The old brakes are squeal like a pig so I decided to get new one's. Is there a lot of work you have to do or a pretty simple job?
Old Jun 15, 2006 | 11:42 AM
corvette-pilot's Avatar
corvette-pilot
I think it took me longer to jack the car up and remove the tires than it did to replace the pads.
Caliper is held on by 2 bolts. I think there is 1 "e" clip that holds a retaining pin then just pop em out.
Old Jun 15, 2006 | 11:46 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Looks pretty simple. Pull a wheel and see what you think. I bought a Chilton manual for $20 last month. It's already saved me way more than that!
Old Jun 15, 2006 | 12:00 PM
slicked25's Avatar
slicked25
Thanks. I have a Chilton and service manual just looks hard but then again I just started the project. I just hope I don't break anything.
Old Jun 15, 2006 | 12:15 PM
rick lambert's Avatar
rick lambert
When my daughter turned 16 I gave her a car, first thing it needed was brake pads, I showed her how to and told her to pay attention......she's 25 now and has done several of her own brake jobs.
Old Jun 15, 2006 | 12:56 PM
bogus's Avatar
bogus
damned near impossible if you leave the tires on.
Old Jun 15, 2006 | 01:05 PM
slicked25's Avatar
slicked25
Well crap, Seattle's a long way. According to the Chiltion's pictures in the brake section there's a girl installing new pads. But then again they make it look so easy. I'll figure it out.
Do you have to have a C-Clamp?
Old Jun 15, 2006 | 01:10 PM
rick lambert
Everytime I do a brake job I use my C clamp, a six incher, without it...good luck. BTW, make sure you take the cap off the resevoir.
Old Jun 15, 2006 | 01:30 PM
slicked25's Avatar
slicked25
Chiltions said, to take 2/3 of the brake fluid from the master cylinder out before getting started. Did you do this or can you skip thru it?
Also, before I jack the car up is there anything else that I may need other than the new pads? Like a pin or nut that might be worn out? Thanks
Old Jun 15, 2006 | 01:46 PM
rick lambert
I have removed fluid sometimes....as the brake pad wears the fluid level drops. I usually have someone watch the resevoir while I compress the cyclinder with the C clamp, if it starts getting to close to the full level I then use a turkey baister to remove some brake fluid.I think the nuts are supposed to be replaced everytime.Don't forget to get a can of brake fluid.
Old Jun 15, 2006 | 01:54 PM
corvette-pilot
As your brakes wear the fluid level drops. So you should top it off as you go.
So if the res. is full you need to take some out because when you push the piston back into the caliper it will force the fluid to go back into the res. You don't want it overflowing !!
Be sure to have the right tools !! I forget the size but you need a big a$$ allen wrench (or torx, I forget) and a pair of e clip pliers I believe.
Old Jun 15, 2006 | 02:31 PM
DonF's Avatar
DonF
When I push in the piston w/ a C-clamp I loosten the bleeder valve so that I don't push anything into the ABS unit & tighten it imd. If your fluid is not clear you might consider at least sucking the old fluid out of the masters w/ a minivac. or bleeding the system until it is clear. This is not a hard job, you can do it by yourself if you have a Minivac. Any shop manual will explain how to do this. Donf
Old Jun 15, 2006 | 02:34 PM
DG'sVette's Avatar
DG'sVette
I usually don't have the luxury of a helper so for me its turn the clamp a little, then check the level, & repeat until done.
Old Jun 15, 2006 | 02:42 PM
Electricblue80's Avatar
Electricblue80
I changed my front pads and rotors a week or two ago. Not a hard job, and followed this...https://www.corvetteforum.com/techti...D=51&TopicID=2
Old Jun 15, 2006 | 04:19 PM
Dave89CC2's Avatar
Dave89CC2
Cruise-In VII Veteran
A little piece of general advice - if you are working on brakes and haven't done it before, find someone who has done it before to assist you.
You can post in your local forum (Forums:Events & Regional) and I bet you'll find a number of people who would be happy to stop by and help. I'd be there myself if you weren't several states away .
To How hard is it to replace brake pads?
