88corvette cooling
First let me explain something. I have put a new radiator, new themostate, new hoses new heater core new A/C system, (compressor, reciever dryer, lines and it is running a R12 system.) I also changed all the fan relays as well. The car runs cool but I notice on hot days in heavy traffic the temp will shoot up to 235 degrees although it does come back down to about 210 to 215.
I have experimented in the garage with the car running at idle I watch the temp go up to 228 and the big fan kicks in and cools the car right down, when I look up under the front of the car I noitice the little fan does not kick on. So I turned on the A/C and let it run and heat up with the A/C on but it never comes on.
I do have the Helms book and I went through it tonight but all it says is how to remove and replace and trouble shoot the big fan,I dont have a problem with the big fan. Does anyone have any ideas ????
The reason I ask is because I have been told that it comes on when you are in heavy traffic but no one has ever explained to me how it works other than that
If the aux. (booster) fan isn't coming on at 228*F give or take 2 degrees, I'd check the fan relay and the coolant fan temp switch. On the 88 most of the relays are the same, so an MAF relay or the manual transmission OD relay can be swapped in to do a quick check of the aux. fan relay.
The coolant fan temp switch should close (0 OHMS) when heated to 228*F or above. The switch should have one green/white wire going into it where it is located in the driver side head between the 1st & 3rd cylinder. You can easily test it by removing the wire where it is attached to the switch by a plastic clip, and grounding it to the block. When you turn the ignition on, the aux fan should run. If not, you have a bad relay, an open in the wires to the fan, an open Fusible Link E,or a bad aux fan motor. Most likely the relay or the switch.
That way i thought I would splice it in and the problem would be fixed.
The only one that is correct is that listed at 238F
Unlike the 86 manual, the 88 FSM consistently states the main fan is on at 226*F in 4 different places. Pages 6E3-A-8, 6E3-C12-1, 6E3-C12-2, 6E3-C12-4. That being the case, I'd say that the 88 FSM is:
A) not inconsistent like the 86 FSM, i.e. more likely correct
B) the appropriate and accurate manual for an 88, for which the question was asked.
As posted, the 88 FSM says the Aux. fan is on at 228*F. What happens on an 86 is obviously anyone's guess, since you state that the 86 manual is not consistent. I'll take your word on the 238*F for an 86, but I am interested in why you picked 238*F from the 3 choices in the 86 manual.
Ok guys so far you have been a big help to me. I went back to my Helms book and you are right the big fan comes on at 228. Thats the one the sits in fornt of the engine..I found my problem with that one I need to replace the wire comming out of the harness that goes the switch in the block. Apparently the little plasitc piece on the wire broke off and it does not sit or plug in very tight to the switch. i repaired that temporarly with some duck tape until i can find the green wire that comes out of the fan harness and splice a new one in. I really dont want to but the whole assembly just for that. So if anyone has any idea I am open to sugestions.
What I wanted to really know was when does the small fan come on in front of the Condensor? I have ran the car in the garage and when it gets to 228 without the A/C running the biig fan comes on at 228. When I start all over again( Let it cool down) and turn the car on again and let it warm up again if I turn the A/C on the big fan kicks on immediately. I never see the litte fan come on?? I have been all through the helms book for my 1988 but I have not seen anything on the little fan in front of the concensor.
I know from being here that the MAIN fan for all years comes on a 228. That IS stated clearly in the 86 manual.
2. If only 88 owners replied to all questions concerning 88, then do you think this question wouldve been answered? I guess you never answer any question regarding any other year besides 88 right?
Of course we know that GM is the all-knowing all-seeing Goliath that never made a single mistake in all the years of C4 production and their manuals are the holy grail of everything.
If Mike's 88 manual page quotation is correct, you should see the temperature in the manual listed.
Otherwise take it out and make it heat up to 238 and see if the auxiliary fan triggers.
