Odd coolant leak
Old Jun 17, 2006 | 08:30 PM
03whitecoupe's Avatar
03whitecoupe
Default Odd coolant leak
A few weeks ago I backed my 86 into the driveway to do some detailing and when I put it back in the garage after I finished, I noticed a small coolant leak on the driveway. I checked the engine bay thoroughly but could see no sign of leaking from hoses , radiator, water pump, etc and I've driven it several times and even to a car show and no recurrance of the leak. Well, yesterday again I backed it out into the driveway for more detailing and again noticed a small leakage after I drove it back into the garage.
For some reason when I back it into the driveway is when the leaks occur. Now my driveway is slightly sloped away from the house and I don't know if that's what's causing the leak and if it is what the heck would that mean?
I crawled up underneath the car as best I could and did see a drip of coolant from under the area where the waterpump is located but couldn't be 100% sure. I don't have the equipment or mechanical aptitude to fix the darn thing so I'll have to drop it of at the shop but wanted to see if anyone had any ideas on what might be the source of the leak and whether it's safe to keep driving it. Sorry for the long post and thanks in advance for any help you can give.
Old Jun 17, 2006 | 08:32 PM
bogus's Avatar
bogus
get under there... I will bet money it's coming from the oil "heater."
It's essentially the oil filter housing. It has coolant lines going through it, and the hoses are prone to leakage from age and such.
Old Jun 18, 2006 | 07:14 AM
ozvette87's Avatar
ozvette87
it is probably from the weep hole on the underside of the waterpump. my old one did this and it did not look like it was coming from there when i got under and had a look.
when coolant leaks from there i think it means the water pump is on its way out and needs replacing.
you can drive it, but not too far or too long..... just till you get to the garage i would suggest from expirience.
Old Jun 18, 2006 | 08:40 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Depending on the location of your leak, front or back, on the ground; mine had a mysterious leak as well ans it was coming from the SURGE TANK the seam on the backside against the firewall had a crack in it and when I was at a slant is when it would leak. I purchased one from Mid America $53 bucks problem done away with.
Then I had a coolant leak from the front which turned out to be the Throttle Body bypass kit I installed and the connections were loosening (found this one by accident) but at first I thought it was the water pump becuase it would drip onto the top of it and run down!
Point is; Look for the highest point of the leak when you search and investigate the location on the ground, is it running along the frame or down something!
Thanks, Matt
Old Jun 18, 2006 | 11:58 AM
03whitecoupe
Well I just crawled underneath and it doesn't look like it's coming from the area of the oil filter housing as it's far forward of that. There's a rail that forms a kind of "V" underneath which is where the drips run down. It looks to be directly underneath where the water pump is located but I still can't determine the exact location of the source of the leak. Any diagnostic tests other than visual to determine if the waterpump is failing? Thanks again.
Old Jun 18, 2006 | 12:10 PM
madmatt9471
I used an extendable mirror and a flash light to look around(you could build one yourself). You should be able to see underneath the water pump, see weep holes, with this as did I. I also took off the Intake Air Inlet off the Throttle Body to look down from the top for another view, which helped tremedously.
I had the same problem as well as does everyone else that is being able to see from underneath! But with patience you'll be able to spot it. Try the small mirror with a good flash light.
Thanks, Matt
Old Jun 18, 2006 | 12:33 PM
bogus's Avatar
bogus
Thanks, Matt
The surge tank didn't come about until 1990 or 1991. His is an 86.
Old Jun 18, 2006 | 12:36 PM
bogus's Avatar
bogus
no diagnostics that I am familier with... perhaps a pressure test.
The thing is, once they start to leak, that is the diagnostic. These are simple mechanical devices with failure based diagnostics... weap=dying.
It sucks... but that's the way it is.
Remove the air intake tube and start nosing around. It could also be a bad gasket, too.
However, the amt of work required to reach the gasket leads me to recommend replacing the pump... they only last so long.
Old Jun 18, 2006 | 12:44 PM
jimmers's Avatar
jimmers
From your descirption of the area, it seems like its the waterpump.
Old Jun 18, 2006 | 02:16 PM
c4cruiser's Avatar
c4cruiser
I had a leaky gasket on the right side of the waterpump where it attaches to the block. It would only leak under pressure and when the pump was turning so I had a tough time initially figuring out where the leak was.
There was enough coolant being lost that the warning light would come on and the coolant level in the radiator would be below the sensor.
I finally got around to replacing the gaskets last month. The job was a PITA to do as I have the R-D Racing Camber Brace on the car and it had to come off.
Getting the A/C compressor off was another biotch of a job. There is one long Torx bolt under the compressor that has to come out in order to remove the accessory bracket. This bolt is not fun
Got a new set of gaskets, cleaned the surfaces and reinstalled. Life is now good (and dry )!!
To Odd coolant leak
