Help with a fuel gauge
Old Jun 19, 2006 | 10:13 PM
elwood blooz's Avatar
elwood blooz
St. Jude Donor '07
Default Help with a fuel gauge
I have an 85 & the fuel gauge went to full & stayed there. Could it be a sending unit, how difficult to repair or should I take her to the mechanic?
Thanks in advance!
Old Jun 19, 2006 | 11:02 PM
VtVette's Avatar
VtVette
Not a bad job at all. Remove the plate that the fuel fill door mounts to (the black piece that has the small hole where you can put the gas cap while filling) and pull the rubber boot out that surrounds the fuel fill neck and the fuel pump/fuel level sending unit is readily accessible.
I would consider picking up a factory service manual either from http://www.helminc.com/ or E-bay. You will pay the price of the manual to have the gauge fixed at a shop, and if you do it yourself you will have the book for further use.
The fuel gauge sending unit is a pretty simple system and is easily diagnosed with the manual. It will tell you how to diagnose a always full situation. I am pretty sure that GM sending units measure 0 to 90 ohms, full to empty. I am not sure which is which, it sounds like the wire that sends signal from the sending unit to the gauge is either grounded or open.
Again, with the factory manual it is simple to diagnose.
hope this helps,
Old Jun 19, 2006 | 11:16 PM
elwood blooz
St. Jude Donor '07
Thanks for the help & the quick response. I'll order the book & the part tomorrow. I'll give an update when work is completed.
Old Jun 19, 2006 | 11:17 PM
Da Mail Man's Avatar
Da Mail Man
Thanks in advance!
***check you pm's......
To Help with a fuel gauge
