engine dies from idle
Old Jun 20, 2006 | 12:43 PM
camaroneil's Avatar
camaroneil
Default engine dies from idle
guys,
got an 86,
it starts up great and idles but as soon as ya press the gas pedal it dies,
if you quickly lift back off sometimes it picks back up,
you have to feather the pedal real gently to be able to pull away,
it's not as bad when warm,
can't get any info from WINaldl,
any ideas,
natt
Old Jun 20, 2006 | 12:48 PM
RRT vette's Avatar
RRT vette
I would start with checking the TPS voltage (.54v). Other than that have you cleaned the IAC and TB lately? Any codes?
Old Jun 20, 2006 | 12:56 PM
tequilaboy's Avatar
tequilaboy
There could be many things wrong. Here's an easy first test:
Disconnect the MAF sensor. You will get an SES light.
If it runs better in limp home mode, where the fueling is driven by the TPS then you have MAF issues.
While I was having MAF issues recently, my car would run much better in limp home mode.
Otherwise, check timing, fuel pressure, sensor data, etc.
Old Jun 20, 2006 | 12:58 PM
Jerris's Avatar
Jerris
This could be a fuel delivery problem. check the fuel preassure from the fuel pump and the fuel filter
Old Jun 20, 2006 | 01:52 PM
5pinball's Avatar
5pinball
if all of above fails try boosting idle up a little and see what happens or better yet go through whole iac tps idle procedure
Old Jun 20, 2006 | 05:15 PM
camaroneil's Avatar
camaroneil
thanks for all the replies guys,
the fuel pump relay was broken,
so i stripped and cleaned it and now it's ok,
will check all the other suggestions tomorrow,
thanks,
natt
Old Jun 20, 2006 | 05:16 PM
camaroneil's Avatar
camaroneil
just thought,
the screws on the tps were all chewed up,
i'll have a look thru other posts,
but is there an easy way to check/ sort the tps,
natt
Old Jun 20, 2006 | 05:25 PM
RRT vette's Avatar
RRT vette
The fuel pump relay being broken, would only make it longer to start the engine. Once oil pressure reaches 4 psi ,with some cranking, the oil pressure switch will run the pump as a back up. But glad to see you are getting somewhere.
Read this to test the TPS:
https://www.corvetteforum.com/techti...D=55&TopicID=2
Make sure the two screws holding the TPS are not loose.
Old Jun 20, 2006 | 05:32 PM
camaroneil's Avatar
camaroneil
thanks,
the car used to take about 10 seconds to start, now it starts instantly,
nice to see this paper is written by lars,
he rebuilt the carb on my 77, and it was a different car,
i took it over to him from the uk,
thanks again for the help/replies,
natt
Old Jun 21, 2006 | 06:33 AM
camaroneil's Avatar
camaroneil
mmmm,
disconnected the iac and nothing changed,
disconnected the maf and still nothing changed,
followed lars paper but i could not get the idle lower than 900 rpm, the idle screw was all the way out,
anyone got a gallon of gas and a lighter?????
Old Jun 21, 2006 | 09:28 AM
rick lambert's Avatar
rick lambert
Maybe this post will answer your question.
http://forums.corvetteforum.com/show....php?t=1389867
To engine dies from idle
