96' Lt4 Overheating (not Simple)
Old Jun 11, 2006 | 05:36 PM
rachels's Avatar
rachels
Default 96' Lt4 Overheating (not Simple)
Bought This 96 Lt4 Collector Edition From
*corvette's Of Dallas*, I Have Replaced The
Water Pump, Thermostat, And Flushed The
Radiator Due To An Overheating Problem. I Have
Only Put 1,247 Miles On It Since I Bought The Car
And Obviously Feel As Though I Bought A Lemon.
I Dont Recomend Corvettes Of Dallas Due To
Substancial Information That Leads Me To Belieive
They Knew About The Problem. (pricing)
Old Jun 12, 2006 | 09:17 AM
pcolt94's Avatar
pcolt94
What are the temperatures hwy and traffic?
Are the fans running?
Correct thermostat?
Who did the work?
Do you know the temperatures that are normal for the car?
Please add the details, I would assume it is hot there, 90+.
Old Jun 12, 2006 | 09:56 AM
ol school's Avatar
ol school
Default overheating
I recently purchased 96 model and had same question.My car runs
200 deg.crusin and in traffic runs up to 230deg.I understand these
cars run hot hot hot. As long as the fans are working and your car
is not smoking chances are your okay...
Old Jun 12, 2006 | 07:38 PM
rachels's Avatar
rachels
Default 96 Overheating
The Fans On The Car Will Only Come On
When The Ac Is On. The Car Will Still
Overheat In Trafic With The Fan On, But
When You Get On The Highway The Car
Will Stay Cool.
Old Jun 12, 2006 | 07:41 PM
rachels's Avatar
rachels
The 96 Vette Stays Cool On The Highway, If
Im In Traffic The Fans Will Only Come On
If I Run The A/c. It Will Still Get Hot With
The Fans On.
Old Jun 12, 2006 | 09:15 PM
pcolt94's Avatar
pcolt94
What are the temperatures? These cars run 200 on hwy and can go to 210-230 in traffic @ 90+ outside. Just to let you know this engine needs a LT1 thermostat for proper cooling operation. Not just any 190 stat. I'm not sure how bad the problems can be if it's wrong. If your above 240 there is a possible problem.
Old Jun 12, 2006 | 09:23 PM
RRT vette's Avatar
RRT vette
anything under 230 and it's o.k. pcolt94 is correct in saying that LT1 needs a LT1 thermostat or just any thermostat will make it run hot. Give us some numbers on the h'way and in traffic. An abnormal increase in temp could be related to many things. Radiator cooling fins clogged up, air in the coolant, fans not working, stuck thermostat, coolant leaks, low coolant, ect.
Old Jun 13, 2006 | 05:44 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Since you say the fans are not coming on id really love to know what temp you call over heating. I also find it very hard to figure out how you come to believe you bought a lemon, and you say you have substantial info to back this up and one of them is price? What price did you pay for the car? Tell us some more about it, condition, mileage, standard of cleanlyness, does it fire up and start instantly when you turn the key? Does it run smooth? Hesitate at all?
Answer all the above for us and we will then be able to assure you that you dont have a lemon.
Old Jun 13, 2006 | 10:59 AM
tjwong's Avatar
tjwong
The Fans On.
It sounds to me that the car is acting normally. The fans are programmed to come on when the temperature hits around 220+ It seems hot, but that is where these things are designed to run at. If you don't like and I don't blame you, get a Hypertech 160 degree power stat. Then send me your PCM and I will reprogram it to run the fans at a much cooler setting.
Old Jun 14, 2006 | 02:41 PM
rachels's Avatar
rachels
The Thermo That Was Installed Is For An Lt1,
But The Car Would Still Get Hot With The
Fans Running, Im Not Saying 230 Hot I Mean
The Gage Is Almost At 260. After I Installed
The Water Pump The Car Overheated Faster
Than I Had Ever Seen, So I Hollowed The
Thermostat, After That It Took About 30min
For The Car To Overheat.
Old Jun 15, 2006 | 02:08 AM
Casethecorvetteman
Are you certain its getting that hot and not just a faulty sensor somewhere? Do the digital and analog gauges read the same or very close to the same?
Old Jun 15, 2006 | 07:48 AM
1LT4ME's Avatar
1LT4ME
The Car Will Still
Will Stay Cool.
Sounds like you're either A) Not getting enough air across the radiator at idle or B) the radiator has some interior blockage. Check to see if there's any road debris blocking up the radiator fins. If not, you might dunk a new radiator in it.
For comparison, I have a '96 CE LT4 and I live in Phoenix. Mine routinely runs around 220*, with an ambient temperature of 110*.
Old Jun 15, 2006 | 08:28 AM
ALLT4's Avatar
ALLT4
My LT4 was running the same kind of temps, not as bad but close. I did the radiator clean routine (debris, leaves, general crap clogging the airflow) cleaned the condenser as well. Replaced the thermostat with a 180 air bleed type. Replaced the coolant with new 50/50 mix, heat cycled the engine several times to get all the air out and now my temps rarely reach 200, usually runs between 180 and 195. I suppose if I had replaced the radiator it would run even cooler.
Old Jun 15, 2006 | 11:58 AM
pcolt94's Avatar
pcolt94
Have you taken the cap off the tank and watched for a few minutes to see if you have flow. You should see fluid movement almost right away. If it is not moving there is no flow. Rev it up, the flow should increase and the level should go lower by maybe 1/2 inch. I hope the connecting shaft between the engine and the waterpump was re-installed.
Does the heat blow hot in the car, another indication of coolent flow.
If the thermostat is right and there is flow then look to the radiator for possible blockage. How was it flushed?
Old Jun 16, 2006 | 04:37 AM
rmwick55's Avatar
rmwick55
have a 96 collectors also. Runs as high as 235 when you sit in traffic,hits that and comes down to about 215, put the AC on she drops 210 to 220 sitting in traffic at 95 degreez, Take her to freeway speeds 190 to195
Old Jun 19, 2006 | 06:53 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Be sure you are checking the digital temp guage, as my analog temp needle would touch the red zone all the time with the stock fan settings. The digital guage would show the correct 232ish temp readings when the 2nd fan will kick on w/o a/c on. The 2nd fan will kick on much sooner with the a/c on. It sounds like you may want to reprogram the fan temp settings as I have and it is fine now (2nd fan on at 190/off at 180 w/ 180 tstat). I'd also check the radiator for debris asothers have mentioned here.
Old Jun 20, 2006 | 01:36 AM
ol school's Avatar
ol school
Reprogram fan Temp settings ??????
Does my 96 have this ???
and rachels why dont you fill out your profile a little bit more then you have
Old Jun 21, 2006 | 10:21 AM
Casethecorvetteman
Yep, it does indeed. However it is totally unrequired if the system is working properly. There is no real advantage to it at all.
Yep, good idea!! Makes it easier for people to help you.
To 96' Lt4 Overheating (not Simple)
