code issues
As far as i'm told this car dosn't have a "MAP"
The car at some times runs great and then at the next stop light starts off bogging,then runs good.On and off. Any Ideas ?????
Any Ideas ?????
RACE ON!!!
Also, regardless, you want to clean and reset your IAC valve.
Now, who manufactured the replacement MAF? (I had problems with a GP Sorenson rebuilt unit).
Very good point. If you haven't disconnected the battery or taken the ECM fuse out this would be a good time to reset the codes. Could be that the code still exist after fixing the problem and just needs to have the memory cleared. I had just taken for granted that this had already been done.
Very good point. If you haven't disconnected the battery or taken the ECM fuse out this would be a good time to reset the codes. Could be that the code still exist after fixing the problem and just needs to have the memory cleared. I had just taken for granted that this had already been done.Yes I cleared the codes by disconnect the battery started clean with code 12 then after a hour run and two engine lightss saying service now 33 popped up
I donno how long that lasted, tho.
RACE ON!!!
I will have to check my reference material... but I am at work, so I don't have it in front of me.
It's been a day. Can you back that up or are you hoping it will go away, as usual?
RACE ON!!!
Paging Mr. Information... Bogus Information.
Originally Posted by bogus
Strangely enough, the 1989 had both a MAP and MAF... odd...
It is pretty irresponsible to make such an bold post like that with no greater conviction, than:
there is something in the back of my head that tells me they have both. I will have to check my reference material...
RACE ON!!!
RACE ON!!!
I checked the book, "Corvette Fuel Injection and Electronic Ignition, 1982-2001."
I was incorrect.
What it was, tho, apparently, there is a feed in the ECM for some years that has both ID'd, but only use one or other... that's the best I can figure.
RACE ON!!!
RACE ON!!!
Yeah...long week....
RACE ON!!!
What you keep missing, dude, is that these things bring out discussion.
Discussion is good.
Remember that.
This place is not full of absolutes... it would be nice, but it just ain't the way it is.
I am sorry if I can't remember everything 100% perfectly, or, have my library with me at all times.
*** EDIT ***
I found where I made my mistake... it was a memory caused by incomplete information. I found where I saw the info - within the damnedable Haynes manual. It has a chart that shows the MAP and MAF within the engine compartment... where 1989 came from, I donno... cause the MAP started in 1991.
Next time, I shall read farther...
Remember that.
It's time to take some responsibility for what you post.
RACE ON!!!
