carb conversion Question, tranny help
I've been speaking with the good people at Rocky Mountain Corvette about how easy the conversion can be. My question to you, speeddemon651, is this....
How easy was the conversion? was there any problems with the fuel pump? any advice for someone who is getting ready to convert from the crossfire to a carb?
Thanks speeddemon651, I bet your vette feels a bit more powerfull after getting rid of that (in my opinion) horrible injection system
Now stfu...and go be unhappy on some other post.
RACE ON!!!
The holley part number, which includes the pump and regulator, is
12-802-1. The pump has 110 gph capacity and can pump up to 14 lbs. Carbs usually only need 5-7 lbs. The regulator does the job and can be dialed right in to what you need.
My set-up applies to an 85. I am not sure about your original set-up but wanted to share with you so you could use this info as a starting point. If your stock set-up is the same as mine then you could use my modified set-up and it will work very well.
My carb is a Holley 670 cfm street avenger. This conversion is quite easy and my car runs very, very well. The overall carb conversion modification exceeded my expectation for overall power, torque, and street manners. Truly, the engine never misses a beat.
I wish you great success with your conversion, and if I can help you please let me know.
Good Luck.
