Drive shaft question
Old Jun 21, 2006 | 12:17 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Drive shaft question
I'm putting in my D44 into my 1993 Auto. The rear is for an 85 so I know I need to drill out some holes. My question here is that will the auto drive shaft fit? I thought I read here that it would but the search is not coming up with crap. Oh, and just to make sure, the holes I need to drill out is the 4 on the bottom that the rods bolt to right?
Old Jun 21, 2006 | 01:24 PM
Casethecorvetteman's Avatar
Casethecorvetteman
Have a look here: http://forums.corvetteforum.com/show....php?t=1406371 i just did this job a few weeks ago. Get the C-beam from a manual car, it fits straight in. You can drill new holes, but its not expensive for a C-beam. I also used a manual car drive shaft as you can see in the pics of my thread. The auto shaft may work, but it was also cheap for the used manual drive shaft, so i bought one. The holes that need to be drilled in the auto C-beam are best drilled at the transmission end, and i believe the manual C-beam is about 15/16ths of an inch shorter than the auto C-beam. There is a tech article on here somwhere for that part that shows the holes drilled and gives the measurement. Ill see if can track it down for ya mate.
Old Jun 21, 2006 | 03:07 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
Ok sorry I was not clear on what I was looking for.
On the batwing there are some holes that I need to drill out because the later C4's had larger bolts then the yearlier ones. I do have a C-beam from a M6 so I'm all set there, I was looking to see if I had to go to a different drive shaft or if my Auto (stock) one would work. Thanks for the help though.
Old Jun 21, 2006 | 06:52 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
The driveshaft from your D36 set up is too long...some have cut and re-welded them to fit but I would not be comfortable with doing that...picking up a manual (D44) driveshaft is not an expensive proposition and will be a direct fit....
Old Jun 21, 2006 | 07:25 PM
scranage's Avatar
scranage
I just did the same thing, using an '85 D44, and I know exactly what you are talking about. I didn't drill out the D44 case, I used 3/8-16 all-thread to replace the asymetrically sized studs from the later design, and adjusted the dogbone brackets for the smaller bolt size by centering some 3/8 washers over the 5/16 holes, and welding them in place. I tried using the 85 brackets first, but the geometry was all wrong.
As for the driveshaft, you can use it in a pinch, but it has almost no endplay left. You have to drop the transmission tailshaft a couple of inches to even get it in place. I have to take mine back out soon (out of balance, the balance mark was gone from my D44, and I must have guessed wrong), and I'll be putting the shorter one back in. The difference in lenght is about 3/4 inch.
Old Jun 21, 2006 | 09:05 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
Here is a stupid question. You say that you have to pull the drive shaft and reinstall it because it's not lined up with a mark on the pig? I have never had to line any drive shaft up on any car. What mark are you going by and are you setting the weight on the shaft in-line or opp. of the "mark"? Heck I've had my stock one out 4 or 5 times and never put it in using any marks.
Old Jun 21, 2006 | 10:35 PM
scorp508's Avatar
scorp508
I can never remember. Is it the driveshaft itself or the yolk that makes up the difference in length? I remember Fastguy grinding the splines off of his 700R4 yolk about 3/4" and his driveshaft fit fine.
Old Jun 21, 2006 | 10:38 PM
scranage's Avatar
scranage
The heavy side of the shaft and the diff yoke have marks on them, they should be reinstalled on opposite sides. The guy who sold me my rear did me nice and sandblasted all the parts, they were very clean. So clean, there was no mark left on the D44 yoke. I took a 50/50 chance when putting everything together, but I have a rumble now.
Old Jun 21, 2006 | 10:40 PM
scranage's Avatar
scranage
Damn good question. Since I don't have the parts to compare, I can't say, but I always suspected taking a half inch or so off the yoke would fix the problem.
Old Jun 21, 2006 | 10:49 PM
scranage's Avatar
scranage
BTW, before you take the drive shaft yoke out, you'll want to have the special tailshaft plug handy (which I don't have) or use your air bleeder (which I do have) to take a tad over 4 qts of ATF off. Otherwise, be prepared for the flood of ATF that washes past the spline.
Old Jun 22, 2006 | 01:41 AM
Casethecorvetteman
No worries mate i didnt know exactly what you were talking about drilling there.
That never happened to me, not a single drip came out at all, and i never drained anything. I guess it would depend on the rear seal.
Old Jun 22, 2006 | 03:16 AM
conv90's Avatar
conv90
Last week I made the swap.
I used a MANUAL driveshaft.
I used the stock AUTO C beam with new holes drilled at the tranmission side.
I Used the stock AUTO yoke.
FYI the DS from the auto was with a label of part #10054289
the manual one with part #10054299
The perfect measurement (center U-joint to center Ujoint) was EXACTLY 19.3 mm (= .76")LESS on the manual shaft. (I was thinking about 1"...)
Probably ALL manual DS are the same or similar (4+3 and 6 speed..) but the code of the manual one (#10054299) if I remember is for 89-91 manual corvettes.
-Beppe-
To Drive shaft question
