scan look ok?
Old Jun 21, 2006 | 03:57 PM
sonomacrew01's Avatar
sonomacrew01
Default scan look ok?
I have what feels like a misfire upon acceleration. It's noticable from 1800-2200 rpms. Doeseverything here look ok?
Old Jun 22, 2006 | 03:35 AM
C4boy's Avatar
C4boy
I can't be of any help with your scan data, but have you checked the obvious tune up stuff? I just cured a similar flat spot in the same rpm range with a cap, rotor & wires.
And if you want to drive 10 mins south, you can come scan my car!
Old Jun 22, 2006 | 09:27 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Need to know abit more info here, like what that DTC code is youre getting, and why you have not set the vehicle type in the options. What mods (if any) do you have?
According to your STerm youre rich, yet the O2s are reading lean. (seems more so on the right bank, and this could be nothing major since the LTerm is saying lean) Really need to know the answers to the above!!!
Old Jun 22, 2006 | 04:16 PM
sonomacrew01
That DTC code popped on showing "service ASR" upon plugging the cable into the computer. After I unplugged, it went away.
I will scan again with the correct vehicle type.
mods include lt4 hotcam, SW full length headers, high flow cats, 3" B&B exhaust. PCM chip and an electric waterpump.
Also have new plugs, MSD wires, MSD coil, new optispark and MSD 6al
Old Jun 22, 2006 | 05:27 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
To really diagnose, we would need to see the data log over a period of time, specifically when the problem is occuring.
I see the knock count field has registered 1108 counts, which means the sensor is picking up knock (either false or real) at some point(s). This could be happening during acceleration (around the 1800-2200 rpm range you noted), causing the ECM to pull timing. That could be giving you the "misfire" feeling you are experiencing.
At this particular point in time (snapshot), the O2 voltage is very low. If this is happening when you hit the throttle, you could be experiencing a momentary lean condition, which will cause the engine to stumble and possibly backfire. The acceleration enrichment or "pump shot" would need to be increased via re-programming the chip to add more fuel when hitting the throttle.
Old Jun 22, 2006 | 05:30 PM
sonomacrew01
scratch the DTC message previously posted. I foundout datamaster can tell you what the number is.. its number 16 lo-res fail
any suggestions?
I have the full .uni file
Old Jun 22, 2006 | 05:50 PM
sonomacrew01
Oh no that $%#@! did not throw code 16 on me. Just checked HELMS and its a problem with the opti not throwing a low-res pulse. That opti is brand new and has less than 200 miles on it.
Old Jun 22, 2006 | 10:11 PM
byebyeL98's Avatar
byebyeL98
That sucks. I don't know anything about the Optispark, but hopefully the FSM has a trouble shooting flow chart for that code.
Old Jun 23, 2006 | 01:19 AM
Casethecorvetteman
Pull off the battery lead and wait ten minutes before putting it back on, then take it for a drive and see if the SES light comes on with nothing connected to the ALDC.
Old Jun 23, 2006 | 08:09 AM
93 ragtop's Avatar
93 ragtop
If it does turn out to be the opti, I seen where one of the venders is having a group purchase on the msd opti. I believe it was $429.00
Old Jun 23, 2006 | 08:53 AM
sonomacrew01
here's what the helm says for troubleshooting DTC16
1) Clear DTC's, crank engine 15 seconds, does DTC set?
done it and yes DTC still sets code 16
2) Ignition off, disconnect ignition system test connector, ignition on,measure voltage on terminal A at the ecm side of the ignition test connector.
First off, wheres the ignition test connector and wheres terminal A
Old Jun 23, 2006 | 09:32 AM
Casethecorvetteman
Have a look in the service manual. It will be in there somewhere.
Old Jun 23, 2006 | 01:37 PM
sonomacrew01
yes
4.72 volts
3)4 to 6 volts, reconnect ignition system test connector. Disconnect distributur connector. Ingition "on", measure voltage on terminal A
4.72 volts
4) 4-6volts, faulty distributor connection or faulty distributor
looks like another person on the MSD purchase. My question is, the manual appears to diagnose this as a problem with a non-running engine.. How come mine runs?
Old Jun 24, 2006 | 09:20 AM
Casethecorvetteman
This is not a certain faulty distributor, it could be a bad connection somewhere. Does your engine run fine? Check and clean all the grounds and the battery terminals.
Old Jun 24, 2006 | 10:24 AM
sonomacrew01
no, the engine feels like it misfires on acceleration and is somtimes hesitant to start.
Old Jun 24, 2006 | 12:10 PM
Casethecorvetteman
Have you pulled out a few plugs to see their condition?
Have you checked that all the injectors are working and in good order? Is the throttle body nice and clean including IAC?
Fuel filter ever been replaced?
Coil-distributor wire not worn out on the back of the water pump?
Old Jun 25, 2006 | 02:53 PM
rick lambert's Avatar
rick lambert
Sounds to me like you're in for a new OPTI, glad I have an earlier C4.
But, I did notice the knock counts..seem high to me.
Old Jun 26, 2006 | 07:44 AM
Casethecorvetteman
Im not prepared to bet on it yet, sure it has the code, but that is no sure indication.
Old Jun 26, 2006 | 10:09 AM
tjwong's Avatar
tjwong
A DTC 16 that keeps coming back is a very good sign, unfortunately. But to be safe check plugs and wires to double check. If not, I have a 95 and up MSD Opti as well. But not for $429 however I have it now. And for $25 less than Summit.
To scan look ok?
