A/C clutch or compressor
Old Jun 21, 2006 | 05:00 PM
compulsivehp's Avatar
compulsivehp
Default A/C clutch or compressor
My A/C has been down for over a year because the cluch went out on it. Should I just replace the clutch or the whole compressor since it has not been ran for over a year? The lines have never been broken.
Old Jun 22, 2006 | 12:01 AM
SunCr's Avatar
SunCr
Can you turn the outer hub by hand? If it isn't seized, it should turn with minimal resistance. If you can't turn it and the engine stalls when you request a/c - you need a compressor, and probably a lot more.
Any obvious leaks such as compressor oil on the hood above the compressor? If so, the shaft seal is gone and you can either replace the seal (about $50 from NAPA) or go with a new compressor.
Old Jun 23, 2006 | 09:10 AM
compulsivehp
The clutch is gone. I am 100% certian of this because I have full 12v being supplied to the clutch with the A/C on. I am just wanting to know if I replace the clutch will the compressor still be good after sitting over a year not being used. None of the A/C lines are leaking or have been broken, my low pressure switch is working and my refridgerant PSI is still good. I do not want to spend $149 on a new clutch just to find out the compressor will not be any good from sitting. Thanks
Old Jun 23, 2006 | 09:20 AM
aminnich's Avatar
aminnich
Ok, with 12v going to clutch and engine running what happens?
Old Jun 23, 2006 | 02:11 PM
compulsivehp
Clutch does not engage.
Old Jun 23, 2006 | 02:26 PM
aminnich's Avatar
aminnich
Ok, if you have 12v to it, and good ground then it is clutch time. If there is no sign of compressor front seal leaking you should be ok.
ps--it is possible to adjust the clutch gap, but if it won't even try to engage that would just be a wast of time.
Old Jun 23, 2006 | 02:28 PM
pcolt94's Avatar
pcolt94
The green clutch wire has the 12 volts on it as you probably know. The black should not measure 12 volts because it should be at ground potential. Make sure it is. Other that measuring the resistance of the clutch to see if the winding has opened up, there is not much left. Except for the diode across the winding and if that shorted you would not have 12 volts at the green wire and the relay would probably burn the contacts.
Can you change the clutch while it is mounted on the car?
Old Jun 23, 2006 | 02:36 PM
compulsivehp
I have searched the forum and found that it is possible. Anybody see any problems with the compressor not working. I have no signs of leaks.Iit has just not run in over a year because the clutch will not engage?
Old Jun 25, 2006 | 10:38 PM
Da Mail Man's Avatar
Da Mail Man
..i believe it can be changed while on the vehicle...
To A/C clutch or compressor
