94: Beginner, advice needed
Old Jun 22, 2006 | 07:12 AM
hollan62's Avatar
hollan62
Default 94: Beginner, advice needed
Hey guys,
I just got a 94 a month ago, shes running a lil hot (up in the 220s in traffic). For now I want to change the fan temps, also in the future I would like to play around with the performance after I learn more about it.
I have a laptop with out a serial port, so I need a serial port adapter recomended, can you guys recomend some cables that I can compare, and some (free) software that will allow me to change the fan speeds for now and some software to mess with the performance in the future.
Kent
Old Jun 22, 2006 | 09:10 AM
Casethecorvetteman's Avatar
Casethecorvetteman
You dont need to change a thing. Its an LT1, they run at those kind of temps and its perfectly normal and wont harm a thing, youre not losing any power til at least 230*F, so leave it as it is
Old Jun 22, 2006 | 09:45 AM
pcolt94's Avatar
pcolt94
If you want to do something first start with changing the thermostat and flush the system. Get the right one for the LT1. That helped me, mine was going bad, did not open all the way. You can also change the radiator, I did with a stock GM replacement which was actually thicker (1 ¼ inch) than the one I pulled out. Brought my temps down 10-15*. I live in FL, 90 to 100 when I drive home in summer. I run under 210 in normal traffic, moving. Stand still for 1 hr and all of them will climb but secondary fan will kick in about 235-239. Normally run, 200 +/- 5*.
Your engine cooling system has to be in good shape before you think about reprogramming. It is a bigger challenge than you think especially with USB. Just a word or caution, if you blow the programming in the chip in the PMC, it is not a user replaceable chip and in some of the ECMs. Then your buying a PCM, not worth the chance for fan settings in my opinion. As far as reprogramming for power, that is a whole different topic and knowledge level for a post.
Fill out your profile, where do you live? Welcome to the Forum
Old Jun 24, 2006 | 06:13 PM
VenkmanP's Avatar
VenkmanP
Originally Posted by hollan62
Hey guys,
Kent
As mentioned above, 220 is not hot.
There is no free software for reprogramming. Cheapest option will cost you about $100.
You certainly don't need to go replacing the thermostat and radiator. The stock items are plenty for a street car. Reprogramming the fans is a much cheaper and easier way to bring the temps down. I've spent a fair amount of time in the desert in temps of 120+*F ambient and my oil temp gets up to high 230s. The other day it was 98*F out and my oil got to 229 (coolant 205).
Read the FAQ in this section, search this forum, and search the internet and you'll find everything you need to reprogram the fans and "mess with the performance."
Old Jun 27, 2006 | 04:34 PM
Da Mail Man's Avatar
Da Mail Man
......... a helms field service manual would be a great addition to your tool box. it has helped me immensly.......
Old Jun 28, 2006 | 09:45 AM
hollan62's Avatar
hollan62
What do you guys think about the "Preliminary factory service manual", which is only 1 book, compared to the 2 book factory service manual. Pros/Cons
Old Jun 28, 2006 | 10:23 AM
Scooter 94's Avatar
Scooter 94
Get both Book 1 and Book 2. You'll search yourself silly trying to find something in B1, only to find out it's actually in B2. Happened to me several times.
Old Jun 28, 2006 | 11:47 AM
Casethecorvetteman
Without a doubt. You need both parts to the book or youre going to think youve been sold a copy with pages missing. It only cost me $119 USD for the pair, i cant remember what the shipping to Australia was but i know it got here in about 3 working days.
Old Jun 28, 2006 | 02:52 PM
hollan62's Avatar
hollan62
I was wondering the pros/cons of the Preliminary FSM 1 book
which was replaced by the 2 book FSM
Im sure theres more in the FSM, but the cost of the Preliminary FSM is really low.
Let me know what you think. Thanks
Old Jun 28, 2006 | 03:01 PM
Casethecorvetteman
There is a reason the cost is really low. The information is really low to go with it.
To 94: Beginner, advice needed
