Code 16 Low res. failure
Old Jun 26, 2006 | 11:58 AM
Tom Piper's Avatar
Tom Piper
I believe there was a previous post that said there was a spark plug wire, or coil wire, in the vicinity of the Opti-Spark harness that was arcing and caused the Opti-Spark signals to be faulty.
http://forums.corvetteforum.com/show....php?t=1409497
Just to be sure, make sure the coil wire from the coil to the Opti-Spark is as far as possible from the Opti-Spark electrical harness.
Tom Piper
Old Jun 29, 2006 | 05:49 PM
sonomacrew01's Avatar
sonomacrew01
update. I haven't touched the car since I started this post. Last night I wanted to show some relatives the car. I started it up and it immediately died. Started it up again and had to keep it running.
Ordered the opti but it looks like I might not get it for a few weeks.
Old Jun 29, 2006 | 06:04 PM
bogus's Avatar
bogus
hm... I wonder what kinda shape the IAC is in???
Old Jun 29, 2006 | 08:47 PM
sonomacrew01
funny you mention that. While unplugging wires, I unplugged the IAC to get to the distributor harness and one of the 4 plastic rings around the male connections of the IAC snapped off. $23 for that little male plug. I am going to replace the IAC and male plug first thing.
Old Jun 30, 2006 | 06:26 PM
sonomacrew01
odd. Started it up again this afternoon. She kept wanting to die on me.I plugged in datamaster and code 16 was gone but continued to die. Shut it off afewminutes and now its running fine, no code but still has the hesitation.
could it be that code 16 is intermittent? I am completely clueless on this.
Old Jun 30, 2006 | 06:30 PM
Tom Piper's Avatar
Tom Piper
Originally Posted by sonomacrew01
....could it be that code 16 is intermittent?.....
If the low-res pulse was missing all the time, the engine would not run at all -- the only way the ECM knows the cam position, is through the low-res pulse.
Therefore, because it runs, even if badly, the low-res pulse has to be there some of the time.
Tom Piper
