Code 16 Low res. failure
Old Jun 23, 2006 | 05:41 PM
sonomacrew01's Avatar
sonomacrew01
Default Code 16 Low res. failure
Picked up the code after scanning and followed Helms instructions testing terminal A at the ECM side of the harness. All signs pointed to a faulty distributor. But upon further investigation on this forum and a camaro forum, with code 16, the car shouldn't have started. My 93 did but ran like crap. Before spending a boatload ofmoney and time on a new opti, how, if any, can I determine if my opti IS bad?
Old Jun 23, 2006 | 05:48 PM
bogus's Avatar
bogus
A code 16 IS a bad opti.
And it will start. It just means that it's dying a slow miserable death.
Old Jun 23, 2006 | 10:02 PM
imaruby's Avatar
imaruby
Its the opti-spark.My '93 was running great most of the time,then it would die on the road.Start immediately and die again.Sometime I could drive it for weeks without any problem,then it would die again.Today it happened again.Managed to get it home,checked the codes.Both 16 and 36,which means opti.
Ray
Old Jun 23, 2006 | 11:04 PM
MikeC4's Avatar
MikeC4
interesting, the low resolution pulses from the Opti tell the ECM which cylinder is next inline for combustion. There are 8 signature pulses, each with a unique pulse width to identify which one is next. Your optical sensor is probably just beginning the death knoll. Sounds like you performed the correct diagnosis along with the error code...How many miles are on your Opti? I hear folks say they are usually reliable up to 75Kmiles or so....(But usually the optical sensor is more reliable than the High voltage cap&rotor components???)
Old Jun 23, 2006 | 11:41 PM
sonomacrew01
brand spankin new. Bought a supposed "factory sealed, new in box" deal from ebay....It has 120 miles on it but was giving metrouble from the day I cranked the rebuilt motor... Bought the opti back in november. Doubt I can get my $$$$$$ back...
Old Jun 23, 2006 | 11:55 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Now that really is a terrible deal. Sorry to hear about it.
Old Jun 24, 2006 | 09:13 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Since no one mentioned it check your wiring.Yes code 16 is caused by the opti but it could be a wire in the plug or elsewhere.Code 36 is the real RIP code but 16 is pretty close to it.Check all connections,use Di-Electric grease when re connceting it.Use the FSM to do the checking.
Old Jun 24, 2006 | 09:27 AM
RRT vette's Avatar
RRT vette
Code 16 will st if the ECM detects the high resolution pulse without detecting the low resolution timing pulse. With this code the engine will crank but not run. I agree with Redeasysport, you might not have connected the circuits correctly and this is why you have had problems since day one. After doing all this and still no good, you might have a defective opti.
"Last thing I did was the first thing that messed up"
Old Jun 24, 2006 | 09:56 AM
SJW's Avatar
SJW
The ECM is seeing a fault with the pulse train coming from the low-res sensor in the Opti. That means that either the Opti has a faulty low-res sensor, or there's an intermittent contact in the wiring harness between the Opti's low-res sensor and the ECM. Check all of the connections.
If the Opti is dying (rotten luck there), I'd strongly suggest you NOT install another OEM Opti. The first-gen OEM Opti is a POS. With the DynaSpark and the new MSD unit available, I see no sense in ever installing an OEM first-gen Opti as a replacement.
Best of luck with it. Let us know what you find.
Be well,
SJW
Old Jun 24, 2006 | 10:14 AM
sonomacrew01
I've followed all steps according to helms making sure it has between 4-6 volts between the ECM and the distributorand it does. I've checked all plug connections and they are good. I've converted the gen1 opti to the gen 2 vented opti properly. I just have a few questions...
1)if there is a bad plug or wire, would it set code 16?
I think I'll pull all the plugs and make a simple battery circuit to see if they are ok. That way there, I know the plug wires are good and I know the harness from the ecm to the opti is good but what about the coil or anything related?
2)Would a bad coil set code 16?
Spending a few hours reading up on troubleshooting this problem could save me some $$$...
Old Jun 24, 2006 | 02:39 PM
STL94LT1's Avatar
STL94LT1
Since you upgraded your opti, that means you had to change the opti wire harness. Have you made sure each wire is making a connection. Working at GM, sometimes we see a new wire harness with a pushed out pin. This can be a real PITA to diagnose.
-Mike
Old Jun 24, 2006 | 02:51 PM
MikeC4's Avatar
MikeC4
-Mike
heh heh...tell me about it! Look what a muffler shop did to one of my O2 sensor connectors wheb I had new catalysts installed. It took me a week to figure this one out. Car was running rich, I was swapping O2 sensors in and out.... and they must have pressed so hard, and bent the pin so bad, that I could not feel the resistance when hooking up the connector ....
Old Jun 25, 2006 | 11:01 AM
Redeasysport
Yes
Sometimes a wire can intermittanly short or open so try wiggling everything while checking for continuity.Get a VOM and check the Ohms from one end to the other of the suspect circuit.As stated above check the plugs especially close use contact cleaner on them and follow my above suggestions.
No
YES
Hope you find it
Old Jun 25, 2006 | 11:02 AM
SJW's Avatar
SJW
1. No.
2. No.
The only things I can think of that could cause a Code 16 are a fault with the low-res sensor in the Opti, a wiring harness fault on the low-res signal line between the Opti and ECM, or a fault in the ECM on the input that reads the low-res signal.
If you are satisfied that the harness connections are faultless, it really does look like there's a 95% chance it's the Opti. Sorry...
Be well,
SJW
Old Jun 25, 2006 | 03:58 PM
Redeasysport
I took a bad plug to mean a wiring plug not spark plug.
Old Jun 25, 2006 | 06:29 PM
sonomacrew01
I'm 100% sure the harness is good. I checked the black/red wire (low res. signal) from the ECm to the opti and it was measuring 4.8 voltsright at the plug into the opti. And the prongs at the opti looked healthy...
Old Jun 25, 2006 | 06:42 PM
SJW's Avatar
SJW
In that case, it's difficult to imagine how you can solve this without a fresh Opti. Sorry about the bad news...
Be well,
SJW
To Code 16 Low res. failure
Old Jun 26, 2006 | 09:04 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You got the Optispark blues, homeboy. Code 16 is the Opti kiss of death. Sorry.
Old Jun 26, 2006 | 10:37 AM
bogus's Avatar
bogus
both codes are of equal importance when it comes to opti failure.
And both can be caused by a bad connector.
Old Jun 26, 2006 | 10:51 AM
RRT vette's Avatar
RRT vette
Be well,
SJW
with SJW these would be the only things that could go wrong to set the code. As stated if you are satisfied with the connections and the wiring test good. Only one other problem besides a faulty ECM (which is not likely, because you would probably have more than code 16 show up) is the opti. Not good news...no.
