Tach reading crazy
Old Jun 23, 2006 | 10:56 PM
todd200's Avatar
todd200
Cruising
Default Tach reading crazy
I was wondering if I could get some help. My brother, Brian Blum, is a member here, but he just moved and doesn't have internet yet. His tach is reading all over the place driving down the road. It's reading like 7000rpm at about 2000. Does anyone know if it the tach filter can be temporarily by-passed. If it can, will it cause any other problems? I figure GM put it there for a reason. It is a 92 with a LT1. Thanks.
Old Jun 23, 2006 | 11:24 PM
mothersworry's Avatar
mothersworry
It can be bypassed and a must if you use a MSD box
Old Jun 24, 2006 | 09:34 AM
Brian Blum's Avatar
Brian Blum
Ok. I've been told it's a white wire off the coil setup, and it has a filter in it. Is the filter in bad spot or a easy spot?
Old Jun 24, 2006 | 12:57 PM
Brian Blum's Avatar
Brian Blum
anyone know the filter's location?
Old Jun 24, 2006 | 01:22 PM
mothersworry
The filter isthe little black box that is attached to the wire harness that comes off the coil. It is probably 2 inches from the coil connector.
Old Jun 24, 2006 | 01:37 PM
todd200's Avatar
todd200
Cruising
I guess you got it Brian. Thanks mothersworry.
Old Jun 24, 2006 | 04:49 PM
Brian Blum's Avatar
Brian Blum
I have two white wires that come off the coil. does only one of them go to the filter?
Thanks in advance.
Brian
Old Jun 24, 2006 | 07:55 PM
mothersworry
The one on the grey connector
To Tach reading crazy
