OK...Need C4 help.
Old Jun 24, 2006 | 12:14 AM
JustForFun's Avatar
JustForFun
Default OK...Need C4 help.
I have an 86 fuel injection system in my C3 thats been converted to speed density. It has ran PERFECT until tonight. On the way home tonight she just shut down (ended up flat bedded home)
Heres what i have discovered.
Fuel pump is running, but not sure how much PSI yet.
Engine is severely flooding...To the point of LOTS of raw fuel is leaking out of the exhaust pipe joint where the cat use to be. Even the collector area of the manifolds (81/82 corvette style) is wet with fuel.
I held pedal to floor once to shut off injectors and clear lines. It did run for few secs before it choked out.
My ??? is..where should i begin. Regulator? if it breaks/Sticks it wouldnt cause this kind of flooding would it?
What about the injectors...surely they wouldnt be stuck to allow this kind of flooding.
Would low pump pressure cause flooding since veh wouldnt crank.
which direction would you go.
Now heres a kicker. about 2 hours earlier i put a pretty strong concentration of SEAFOAM injector cleaner. Think this could have caused the issue?
Im gonna get a good nights rest and tomorrow morning im at it. Im hoping a golden trail of ideas and tech info will be here by 8am est
Old Jun 24, 2006 | 12:19 AM
vader86's Avatar
vader86
It almost sounds as if the injectors are all stuck open or the plugs are completely fouled.
I think I'd start by checking fuel pressures at the rail, while running and note what the pressure does immediately after shutdown.
Old Jun 24, 2006 | 12:21 AM
JustForFun's Avatar
JustForFun
you know thats exactly what i was wondering, but man how in the world could all the injectors go bac at same time. Surely the seafoam cleaner couldnt/wouldnt cause this
What sensor (TPS) controls the injectors fiiring wide open.??
Old Jun 24, 2006 | 12:23 AM
vader86's Avatar
vader86
I've heard of Seafoam causing an engine to hydrolock here before, but not this problem.
Old Jun 24, 2006 | 12:28 AM
CorvAdel's Avatar
CorvAdel
[QUOTE=JustForFun]you know thats exactly what i was wondering, but man how in the world could all the injectors go bac at same time. Surely the seafoam cleaner couldnt/wouldnt cause this
Don't know about Seafoam...Do know about ONE injector being stuck open enough that when I pulled the dipstick it had a strong fuel smell.
I suggest you check the oil before attempting to start again.
Mine happened after a rebuild, and all injectors being cleaned and checked. Turns out I did two oil changes before the car moved an inch...!
With a fp gauge connected turn ig. on for a few sec's, turn ig. off and watch the needle drop...if a stuck inj. is the problem.
Old Jun 24, 2006 | 12:30 AM
JustForFun's Avatar
JustForFun
i never realized this much gas flowed through in short amount of time. Theres was a huge puddle dripping from under veh
Old Jun 24, 2006 | 12:31 AM
tequilaboy's Avatar
tequilaboy
Maybe a bad diaphragm in the fuel pressure regulator allowing fuel to enter via the vacuum line.
Old Jun 24, 2006 | 08:12 AM
JustForFun's Avatar
JustForFun
here we go..
Old Jun 24, 2006 | 08:38 AM
RRT vette's Avatar
RRT vette
I would do as suggested and get a fuel pressure guage on and check the pressure when the pump primes, when the engine is running, and after shutdown for a quick drop in pressure. You need to also check the viscosity/smell of the oil because it probably has gas in it and needs to be changed. You can pull the vacuum off the FPR and look for gas inside. You wouldn't think all the injectors would be stuck open, but I've heard of stranger things happen. You can also ohm the injectors one at a time hot and cold and should be around 16 ohm +/- a ohm or two.
Old Jun 24, 2006 | 09:01 AM
mseven's Avatar
mseven
I agree with much of what has been said, to add to this I would also pull the plugs to see if it is truely one or more injectors staying open.
Old Jun 24, 2006 | 09:04 AM
RRT vette's Avatar
RRT vette
good point.
Old Jun 24, 2006 | 09:09 AM
JustForFun's Avatar
JustForFun
heres what ive4 found thus far.
41lbs of psi during intial key on.
crank engine pressure drops to 35lbs
turn car off and pressure slowly bleeds to zero
crank car while pressure is fallinjg and psi is around 20
hold pedal to floor and crank engine 0-5 psi
Old Jun 24, 2006 | 09:17 AM
RRT vette's Avatar
RRT vette
How long did it take for the pressure to bleed down to zero? If less than 30 minutes you have leaking injectors, blown diaghram in FPR, or check valve not holding. Since the is evidence of gas in the exhaust I believe you will have leaking injectors.
Old Jun 24, 2006 | 09:20 AM
JustForFun's Avatar
JustForFun
30 min
try 15 secs
also i checked injector resistance. 18 on pass side 4...and 20-21 on the drivers 4
Old Jun 24, 2006 | 09:32 AM
RRT vette's Avatar
RRT vette
15 sec is mighty quick. If you checked the vacuum on the FPR for fuel inside and didn't find any I am going to say you are in need of new injectors ($200-$250/set).
Old Jun 24, 2006 | 09:50 AM
SJW's Avatar
SJW
Sure sounds like either a blown FPR or injector(s) stuck wide open. Shouldn't be too difficult to figure out which of the two it is.
Be well,
SJW
Old Jun 24, 2006 | 10:56 AM
JustForFun's Avatar
JustForFun
latest....
Now when turning on the key, the fuel PSI is about 20 as soon as the pump stops priming it falls to zero.
couple of times i heard a click under the hood, like a injector ckicking and when i turned the key pump psi went to 45 and held at 30 after prime.
To OK...Need C4 help.
Old Jun 24, 2006 | 11:07 AM
RRT vette's Avatar
RRT vette
latest....
When you turn the key on you will hear a humm as the pump primes the system for about 2 sec. then it cuts off and there is a clicking noise as soon as the pump stops. You can see this if you watch the guage as it primes and when it clicks the needle will jump. You should hear no injector noise until you start cranking on the engine and the ECM sends voltage to the injectors. Usually you will hear the injectors clicking as the engine runs and is normal, too a certian point. The 20 psi you stated when the pump primes for 2 seconds, is low, and should be closer to 40 psi. I don't think you have a fuel pump problem from the rest of your statement, but more a FPR or injector(s) problem.
Old Jun 24, 2006 | 12:35 PM
vader86's Avatar
vader86
I would just go ahead and replace it all, injectors and FPR, if i had the money.
A new Holley adjustable regulator and new Ford injectors, and I dont think i'd ever be using Seafoam again.
Old Jun 24, 2006 | 02:16 PM
JustForFun's Avatar
JustForFun
Exactly what mi going to do. Guess ill run to summit tomorrow. What injectors? why Ford? Which ones?
