Help! Supercharger issues.
Old Jun 24, 2006 | 12:58 PM
blown93vette's Avatar
blown93vette
6th Gear
Default Help! Supercharger issues.
Hello all. New to the Forum. Hopefully somone can give some direction. I am running a Vortech on a lightly modded 93 and it has provided great all around street driveability and reliability for the past year or so. One major problem. At full throttle, the motor craps out at 4800rpm. It almost feels like the "fuel cut" I used to experience in my turbo cars. Played with the timing via the BTM and the more I back off timing, the worse it will run. Checked the rev limiter and its set for 6200. I am running the 10:1 FMU with the T rex pump. Is this a fuel related problem? Never had the car tuned (speed density). It pulls real strong to the 4500-4800, and then boggs out like a bucking bronco. It's getting really old having to granny shift every time full boost is just coming on. My buddy with a modded 03 Cobra loves it as he pulls further and further away with every shift... HELP!
Old Jun 24, 2006 | 07:40 PM
Scott94C4's Avatar
Scott94C4
Are you using any kind of monitoring software (such as datamaster). Could it be knock retard?
Have you done any valve train work on your car? If not, you shouldn't be reving it up to 6200 RPMs.
What about putting it on the dyno and checking the AFR?
Old Jun 24, 2006 | 09:00 PM
blown93vette
6th Gear
No valve train work yet- would shift at 5500 if I could... No data software yet either. What is the recommended setup? I guess a dyno tune is in order. I'm in the Chicagoland area. Any reputable shops anyone could recommend?
Also, I've heard of increasing injector size to 38 or 42 and going with a smaller FMU or getting rid of the FMU all together. I don't want to hurt driveability, as the car is a daily driver.
PS. My friends and I are arguing about temp sensor location.. Should it go right after the aircleaner on the inlet tube or in the bung on the blower discharge right before the throttle body?? I've tried both and there was no change in performance or driveability.
Old Jun 25, 2006 | 02:19 AM
Scott94C4's Avatar
Scott94C4
My IAT is right before the TB. It will make a difference, but for it to be accurate, you want it to be the temp it will experience in the engine (hence not before the charger).
The general concensus is to get rid of the inline fuel pump and the FMU and upgrade to a larger intake pump and 42# injectors.
I recommend lucas (disc) type injectors as they have faster opening times. BUt either way, you shouldn't have a problem with idle or driveability with 42# injectors (it is more once you get up to 60#+ inj.).
The High RPMs on a stock LT1 valve train can be devistating. I recommend lowering your RPM (although not causing your problem).
I don't know anyone in the chicagoland area with experience in vettes (try your regional forum for that information). Sorry.
TTS datamaster and a cable from www.akmcables.com is recommended. You get 20 free datalogs with the software, but the cable is about $60. Well worth it. Definetly get it tuned on a dyno.
Also, drop me a line and let me know how it works out. GL!
Old Jun 26, 2006 | 11:17 AM
RVY's Avatar
RVY
Change the fuel pump. Lucas injectors came with my Vortech kit. They leaked.
Old Jun 26, 2006 | 12:58 PM
Mo_Bandy's Avatar
Mo_Bandy
My "guess" is you are seeing knock retard and it is pulling the timing... You really need to get a data logging program to see what is really happening, I would halt any full throttle runs until you see what is really happening, the stock pistons will not take alot of abuse...
also another thing to check is your plugs, they should be at least one step colder and gapped around .035 , it could be blowing out the spark.
I have relocated my IAT to the amient air, but when i had mine setup in earlier setups, it would richen up the mixture... as the intake air increased, do you have a boost guage? Are you pushing 6 or 8 pounds of boost?
Again it keeps coming back to you need either wideband O2 sensor or again a data log program to see what your O2's are reading...
Hope this helps,
MO
Old Jun 26, 2006 | 05:53 PM
blown93vette
6th Gear
Thanks for the knowledge guys.. Looks like I have some work to do.. Any experience with an intercooler or meth injection on a Vortech kit?
Old Jun 27, 2006 | 10:40 AM
tjwong's Avatar
tjwong
Are you sure that the T rex pump is running? If that pump isn't running for whatever reasons, it would become a restriction in the fuel system at higher RPMs and under load. I got rid of that POS, installed a larger single in the tank pump and a Kenne Bell Boost-a-pump that over drives the pump when boost hits 3 PSI.
Old Jun 27, 2006 | 11:56 AM
TONYDEE64's Avatar
TONYDEE64
You are very lucky in that you have Dan Bills at Finishline Performance in Naperville. He is the only person who I will let tune my FAST ecu. They are a supporting vendor of this site.
http://www.flp2win.com
Old Jun 27, 2006 | 08:24 PM
blown93vette
6th Gear
TJWONG- I'm sure the inline pump is working as it's pretty loud.
I've used 255Lph in tank pumps on my old turbo cars. I think the T rex is a 255LPH and the stock in-tank is 190? What in tank pump are you big power guys using as I am thinking of going bigger with my 93 daily driver? (Don't want to change the pump twice).
I'm not sold on the Kenne Bell boost a pump, as my buddy with a highly modded 03 Cobra has burned up two pumps with it. Although the trick of hard wiring the pump to the battery worked well on the turbo buicks..
Old Jun 27, 2006 | 08:28 PM
blown93vette
6th Gear
TONYDEE64- Thanks for the info. I actually live in Naperville about 3 miles from FLP. I guess I'll give them a call. Most of my LS1 and Cobra Mustang buddies send there stuff up north in Bloomingdale IL, but no one has any experience with pre 94 non mass air stuff... What's the best bang for the buck tuning system out there for me? Just a wideband and a meter? Who reprograms the ECU's?
Old Jun 28, 2006 | 11:19 AM
SHINOBI-X's Avatar
SHINOBI-X
a LM1 Innovative A/F ratio is getting pretty inexpensive now-a-days. You can monitor the A/F constantly after mods and adjust the FP when needed to help compensate for whats been done. If you tune its more important by far,but if you will never tune then its probobly not a big "NEED".
To Help! Supercharger issues.
