Question about installing new coolant sensor
Old Jun 24, 2006 | 10:49 PM
85C4fanatic's Avatar
85C4fanatic
Default Question about installing new coolant sensor
I am putting a new coolant sensor in the lower base and my question is should it be installed dry or with a teflon sealant on part of the threads?
Old Jun 25, 2006 | 12:08 AM
rdcamero's Avatar
rdcamero
Hi I would put the teflon tape on it.Just put a little on the back part of the threads where it will seal good but be sticking into the opening.
Old Jun 25, 2006 | 03:13 AM
goldeneye_vet's Avatar
goldeneye_vet
I always use teflon tape. Not a leak yet whether its an oil based sensor or coolant based.
Old Jun 25, 2006 | 06:27 AM
RRT vette's Avatar
RRT vette
Teflon
Old Jun 25, 2006 | 07:59 AM
85C4fanatic
I was told by the parts counter person that because it is bress it doesnt need sealant. He also told me that by doing it the sensor wouldnt ground properly. I thought that I could put a little on a few top threads as extra measure but want to get some feedback on it first.
Old Jun 25, 2006 | 08:07 AM
RRT vette's Avatar
RRT vette
You are talkig about the CTS (coolant temp sensor) that mounts to the front of the intake manifold...correct?
Old Jun 25, 2006 | 08:39 AM
His93C4's Avatar
His93C4
I replaced mine several months ago. The original one had teflon tape on it, I also used teflon tape on the new one. No leaks, sensor works great.
85C4fanatic
That's the one!! Correct.
Old Jun 25, 2006 | 08:46 AM
RRT vette's Avatar
RRT vette
Then yes, use teflon. The sensor has two wires, one is a ground (black wire) that is also connected with the TPS ground and the other (yellow wire) is signal form the ECM that is 5v. The sensor measures the engine temp and sends the info to the ECM for fuel control/drivability. It can be ohmed to tell if it is bad or not. As you know the teflon will prevent coolant leaks.
F*---------C*--------OHMS
210--------100--------185
160--------70----------450
100--------38----------1800
70---------20----------3400
40---------4-----------7500
Perhaps more info than needed.
Old Jun 25, 2006 | 09:15 AM
85C4fanatic
In this case I dont have to test an existing one. I am replacing a base intake and the replacement one doesnt have one installed and my old base is going to another forum member and I didn't want to take it out of that base.
As for too much info that type of info is always useful to someone at some point. Thanks for the help. So should I use teflon tape or permatex teflon thread sealer?
Old Jun 25, 2006 | 09:18 AM
RRT vette's Avatar
RRT vette
Teflon tape should do the trick!
To Question about installing new coolant sensor
