Exhaust question
Old Jun 25, 2006 | 10:28 AM
Ks_96_LT4's Avatar
Ks_96_LT4
1st Gear
Default Exhaust question
I have a 1996 LT-4. The cats are completely blocked on it. What I was wondering is would it be better to hollow them out or replace them with just pipe? And on that, does anyone make replacement pipe for the cats or do I have to find someone? Thank you.
Old Jun 25, 2006 | 10:49 AM
c4cruiser's Avatar
c4cruiser
If you life where emissions testing is required, you will need to replace them with factory cats or an aftermarket version. There are some high-flow cats available that should work well. Even if you don't have to go thru testing, cats do help the environment and keep the air cleaner.
If you eliminate them, you will most likely need to replace the O2 sensors with heated versions. The stock sensors need the heat from the cats to work properly.
Federal law makes it a crime (IIRC, it's a $10,000 fine ) for a shop to remove catalytic converters and not replace them. The chances are that no reputable shop will cut them off and insert straight pipe.
I would go with replacement OEM cats or an aftermarket high-flow design. The OEM cats do flow pretty good and you can install shorty headers made for the LT1/4 motors that will add HP and torque and the cats will bolt up to them.
Old Jun 25, 2006 | 10:52 AM
RRT vette's Avatar
RRT vette
C4cruiser gave you the correct answer.
Old Jun 25, 2006 | 11:24 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
I think the 96s come with heated O2 sensors. I'd look for some used factory cats(cheap route), or upgrade to headers, longtubes, with some bullet cats(more expensive route). What are your long term visions for the car performance-wise?
Old Jun 25, 2006 | 01:29 PM
rickneworleansla's Avatar
rickneworleansla
I only have one that is breaking apart but that's what motivated me to do headers and cat delete from Exotic Muscle. At least I won't have to worry about them breaking again. I heard someone mention gutting them could create more turbulance and possibly give a little less hp?? I would do a pipe if you go that route to make sure. Hopefully emissions arent strictly checked in your area. I'm not sure who makes this for stock exhaust manifolds.
Old Jun 25, 2006 | 01:40 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Replace with high flow cats. Good for performance and the air we breathe!
Old Jun 25, 2006 | 02:18 PM
Fancyazz's Avatar
Fancyazz
mine came apart not too long ago and i pulled the pipes off and gutted the material inside. Then reinstalled the factory cats that where hollowed out and no rough running. Until i get the money to put on headers and new cats im running around with gutted factory units. I think i maybe only picked up 5-10hp max. Didn't feel much improvement on a stock LT1.
To Exhaust question
