Opti replacement--Delteq????
Old Jun 26, 2006 | 08:56 PM
JTHVETTE's Avatar
JTHVETTE
Default Opti replacement--Delteq????
What after market systems are there to replace the GM Opti distubitor?
Does any one have a DIY drawings or schematic? I see that Delteq has a "Bare Bones" package. I am trying to find a system that I can assemble and install my self if possible.
Help!
JTHVETTE
Old Jun 26, 2006 | 09:04 PM
sonomacrew01's Avatar
sonomacrew01
If you have a good Helms manual, any opti replacement is a day job.
Dynaspark, MSD and GM have opti replacements. I put in an OEM and it was defective from day 1 so I'm heading down the MSD route. There's a GP in the for sale section from TByrne.
Old Jun 26, 2006 | 10:00 PM
MikeC4's Avatar
MikeC4
here is a decent article explaining some of the major steps of Opti replacement:
http://corvettefever.com/howto/16758/
I'll look for a more detailed procedure and edit this post with that info if i can find it....DOH
ahh, here it is:
http://www.houston-f-body.org/tech/optispark/
Old Jun 26, 2006 | 10:16 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Delteq still needs the opti for the signal.If you have a code 36 forget it it wont work.I have a Dynaspark and have had no issues with it.
Old Jun 26, 2006 | 10:23 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Your profile lists a 96 which means you have the Gen2 Opti; much cheaper and more reliable (waterproof) than the Gen1. Otherwise the Dynaspark or MSD.
Old Jun 28, 2006 | 08:12 PM
MikeC4's Avatar
MikeC4
I had no problems with my OEM Gen2 Opti replacement.
Old Jun 28, 2006 | 10:19 PM
SJW's Avatar
SJW
As others have correctly noted here, the Opti cannot be completely replaced by the Delteq or any similar DIS conversion setup.
The Opti serves two functions:
1. It provides low-resolution and high-resolution timing pulses which allow the ECM to calculate camshaft position, velocity and acceleration. The ECM uses this, along with input from numerous other sensors (MAF, MAP, IAT, ECT, VSS, KS, etc) to calculate optimum spark timing and injector pulse width and timing. The ECM cannot manage spark timing or fuel metering without this input from the Opti.
2. It serves as a conventional spark distributor. This function of the Opti is what can be replaced with the Delteq (or LTCC) setup.
In short, you can move the high-voltage portion of the ignition system out of the Opti with the Delteq or LTCC, but you still must retain the two optically-derived timing pulse signals from the Opti to the ECM.
The Delteq is a good package, within the limitations of what it can do. It does what it does very well. But it cannot eliminate the Opti altogether. If you have confidence in the optical section of your Opti, the Delteq or LTCC may be attractive to you.
If you want a true, bolt-on aftermarket solution for the deficiencies associated with the OEM Opti, consider the DynaSpark or the new-to-the-market MSD unit. The Dyna has a good performance record in the field. The MSD is still a bit of an unknown in terms of its performance (with respect to long-term reliability).
Be well,
SJW
To Opti replacement--Delteq????
