The counts go down as the engine warms up because as the engine warms, the ECM calls for a lower idle speed. Even the high side on that idle speed range is none too high. I'd start by making sure the IAC and passages are clean. I would expect the idle speed to be ABOVE spec, with a vacuum leak, not lower. It is possible you have a little of both.
Trying to solve a slight idle problem in my 1985 stock L98 (varies between 580-620).
I scanned the car and the IAC counts are all over the place, then slowly decrease as the temp goes up.
I think I have a vacuum leak (I have yet to verify that), and I read that the IAC can reveal that.
Can anyone tell me what values I should be getting here?
starts at about 140, and goes down into single digits.
Cold start mine at 160 and as the car heats up (idle lowers, goes closed loop etc.) counts will goes down to the set value around 40. That does change a little bit on different days but doesnt wander around like what you mentioned. What I can tell you is as the idle lowers so do the counts, but if I reduce the f.pressure at a point it will lower the idle, but it will increase IAC counts/steps.
I think to answer your question counts moving that much to control or adjust idle that much sounds like a vac leak. On a stock set-up I thought the counts should be around 20. hope this helps
I should have mentioned first, that the IAC is new, and the passage and throttle body are clean. New gaskets for the throttle body and passages too.
RACE ON!!!
I didn't know that IAC counts when down as the engine warms, It seems as though my IAC is working in that reguard, except that the lower values are way lower then the should be from what Mseven says...
My counts dropped to 8...
The idle isn't off by too much, so I doubt the answer will be obvious.
I'm going to keep searching for that vac leak if you guys think that could be present, but what else effects the IAC counts? A/F ratio? Fuel pressure?
counts dropped to 8... The idle isn't off by too much, so I doubt the answer will be obvious. I'm going to keep searching for that vac leak if you guys think that could be present, but what else effects the IAC counts? A/F ratio? Fuel pressure?
Fuel pressure will definely effect IAC counts.
The number is actually a point where the computer can compensate. As I stated I think is 20 counts, 10 may not be far off. If you get the IAC counts to low it will try to drop below the programmed idle , and if to high (out of range) will not let the idle come down to the programmed idle speed.
Mine being modified (and idle programmed for 825) 40 counts is what I am looking for, but anything from 30 something to 47 or so is allowing the IAC to be within range to compensate.
One thing I like to do is after cleaning the IAC with throttle body cleaner is to put a drop of oil on the stepper motor shaft. Maybe going back through it and re-set the min. air wouldn't be bad idea either.
the iac counts need to be 20-50 to control idle properly. there are 2 ways to adjust your iac counts, open or close the thottle blades until desired counts are met. if you try to open the blades to lower your counts and it is open all the way drill 1 1/16" hole in each blade then readjust your blade position.
I think that the IAC counts are only "driven" by the ECM attempting to maintain the programmed idle speed. If reducing the fuel pressure lowers the idle speed, then I think it is the speed, not the A/F ratio, as sensed by the O2, that causes the IAC counts to change, as the ECM tries to maintain the idle speed.
I also believe that an otherwise healthy L98 won't idle as high as 580-620 rpm on only the air, 8 IAC counts can provide. If the minimum air adjustment is proper, there must be a vacuum leak.
Hi. I have an 85 4+3 and I think that an idling of 580-620 seems within acceptable limits. False air may be the reason and one place there may be false air making this small variation may be in the throttlebody shaft. The wear and tear there may cause some air to come in. And that will change as there will be too much room for the throttle shaft to move in. I have a much more progressive cam than stock which made the idle vary more than this. I have accepted that as the idle is a bit lopy. But a variation of 40 rpm is not much after my opinion, but nothing is better than if you really find the reason and made it stock stable.
