fuel pump pressure
Old Jun 28, 2006 | 12:44 AM
imaruby's Avatar
imaruby
Default fuel pump pressure
My '93 has been dying on the road.Got a code 16 and 36 which indicates bad opti-spark.I was checking the fuel system with pressure gage.When I turn on the key (no start)the pressure goes to 47# then falls back to 40#.Is this typical or is the pump bad?If I start it the pressure stays at 40#.Anyone had this happen?
Thanks for any help.
Ray
Old Jun 28, 2006 | 12:59 AM
bogus's Avatar
bogus
the pressure will spike, once the pump shuts off, the pressure will back off a bit.
replace the opti.
Old Jun 28, 2006 | 01:29 AM
drock92's Avatar
drock92
Sounds like the correct pressure.
Old Jun 28, 2006 | 04:35 AM
RRT vette's Avatar
RRT vette
replace the opti.
This should answer the question. Pressure sounds good, it's dying because of the opti.
To fuel pump pressure
