Ok so I just got my gen 1 dynaspark and all looks well but I noticed that the input shaft has some play in it, and wiggles from side to side, im not pushing hard on it or anything like that. Just thought I would ask you guys and see if you noticed the same with your dynasparks. I just dont want to install the thing only to have it tear itself apart from the inside out. I will measure the play when i get to work tomorrow and I already emailed dynaspark to find out the acceptable amount of input shaft play. In the mean time I was wondering if anyone has had there rotor rub on the inside of the cap due to excesive bearing play?
They have play in the shaft as do all Optis do.They provide a list of measurements to do before install so check those out. I believe you can pull the shaft out completly as you can with a GEN I OEM opti.I wouldn't worry about it.I have never heard of a proprly installed Dynaspark failing yet.Mine is going on 2 yrs and runs fine.The worst mistake you can make it to route the vacuum lines in reverse or in correctly.That will cause a vacuum inside that will damage the rotor
I'm not sure about the early Opti-Spark, but the vacuum vented Opti-Spark relies on the camshaft to support the rear of the Opti-Spark shaft.
The Opti-Spark shaft is supported at the front by the internal ball bearing. That same shaft is inserted into the camshaft center hole and also has two small O-rings to take up the play -- this is the rear support for the Opti-Spark.
The combination of the support of bearing at the front and the camshaft at the rear makes the Opti-Spark shaft fairly rigid when installed.
This is the reason you should always install new O-rings on the Opti-Spark shaft -- better support.
I've wondered if any Opti bearing failures were due to no, or defective, O-rings at the rear allowing the shaft to "whip."
There was zero play in the shaft of my Gen I dynaspark which I just installed over the weekend. If i'm not mistaken, most all the measurement specs on the dyna instruction sheet pertain to Gen II, and/or modified engines.
The water pump shaft needs two o-rings (one for engine spline and one for w/p spline), but there wasn't one on my dyna, nor do I remember mention of one in the instructions. Also, no o-rings included in the dyna package, so I dunno. Installed mine without o-rings, it's running great.
I don't think the early Opti-Sparks used O-rings, just the later ones (vacuum vented) did.
