Quick Alternator install question....
Old Aug 30, 2001 | 10:59 PM
Nomar116's Avatar
Nomar116
Default Quick Alternator install question....
How important is the black support rod that connects to the driverside exhaust manifold? It wont work on my Hooker headers with the elliminator. Is it ok to just leave it off and get everything else plenty tight. That would leave the alternator hooked up via the power steering pump bracket, and the air pump eliminator bracket.
Paul
Old Aug 31, 2001 | 04:19 AM
JAKE's Avatar
JAKE
Default Re: Quick Alternator install question.... (Nomar116)
At low speeds, you shouldn't have a problem, but when the R's climb, vibration could cause the belt to jump off, and that's bad news.
If at all possible, re-install the brace.
There's got to be a way to install a bolt in the header to allow you to mount the brace.
Give Hooker a call and see if they make something that'll work.
Jake
Old Aug 31, 2001 | 08:46 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers:
Lingenfelter says you don't need it
I have run all summer without it. no adverse effects
:seeya
Old Aug 31, 2001 | 08:53 PM
Muffin's Avatar
Muffin
Default Re: Quick Alternator install question.... (jackdaroofer)
I ran an F-body long and hard without and could not tell it was not there. Nice to have but not essential.
To Quick Alternator install question....
