Problems starting lately
Old Jun 30, 2006 | 07:51 AM
  #41
rick lambert's Avatar
rick lambert
Sounds to me like he just proved his check valve on the fuel pump is leaking.
Old Jun 30, 2006 | 09:28 AM
  #42
n1kki6's Avatar
n1kki6
Originally Posted by RRT vette
You had pressure in the system the second time.
Right, but shouldnt their have still been prssure the first time. NO matter when I check the pressure before the first start or after it still reads about 40 psi.
As far as ohming them I need to wait till my buddy comes out with his ohm meter, I can't find mine.
Old Jun 30, 2006 | 09:29 AM
  #43
n1kki6's Avatar
n1kki6
But is the check valve something that can just be replaced, do I need to replace the whole fuel pump? I searched napa for check valve and didn't come up with anything.
Whats crazy is it fired right up again this morning, I will see what happens when I try to start it at lunch.
Old Jun 30, 2006 | 09:54 AM
  #44
rick lambert
Yeah, bad check valve=new pump. Could be your fuel pump is just getting tired, your fuel pressure sounds fine, but it seems like at some points it's flowing back into the tank thru the pump, which indicates the check valve.I only come to this conclusion because it sounds like pressure holds everywhere while the feed line is clamped...but loses pressure when you unclamp it.
Actually, now that I remember back, I had the same symtoms you have when my fuel pump finally died.
Sometimes it would fire right up, sometimes I had to play with it...finally just went poop, and I knew I wasn't getting any fuel.
Old Jun 30, 2006 | 10:02 AM
  #45
n1kki6's Avatar
n1kki6
Awesome, going to pick up the parts on the way home from work and fix it tonight.
Old Jun 30, 2006 | 08:04 PM
  #46
n1kki6's Avatar
n1kki6
Got it in but I am almost wondering if this isn't it since it starts the same after 24 hours of sitting as 3. The pressure after 24 hours is going to be low as well. After installing everything the pressure is still on at 40 when I click the key foward. This is what it was at when I had the bad gas and I wasn't having this problem.
Old Jun 30, 2006 | 08:10 PM
  #47
RRT vette's Avatar
RRT vette
Not sure I understand you n1kki6, when you turn the key the pressure reads 40 psi? Thats o.k. ... other than that is it starting like it should or is it not?
Old Jun 30, 2006 | 08:20 PM
  #48
n1kki6's Avatar
n1kki6
The first start after sitting even overnight it will read 40 psi but still turn for about 5 seconds before starting. Then if I shut her down for a few minutes it start fine. So it only hard starts after sitting for more than a few hours but even then the pressure will still read 40 psi when I click the key foward.
Old Jun 30, 2006 | 08:33 PM
  #49
RRT vette's Avatar
RRT vette
O.K. if you get in it for the first time of the day and try to start the engine it takes about 5 sec to start. Now if you try and stop then try again it start on the first turn correct? If so, you know there is pressure at the rail (40 psi).
It could either be spark or injector pulse. You can use a test light on the injector pigtail and have someone attempt to crank the engine and the test light should light up at that time. For spark use a spare plug and put it in one of the spark plug wires and hold it about 1/2" or so, from the exhaust manifold and have some one crank the engine and you should see a blue spark. Try both of these when you suspect it will take the 5 sec to start the engine. BTW, have you ohmed the injectors yet, this could show you something as well.
You can also try the fuel pressure test as you did earlier and see what happens.
Old Jun 30, 2006 | 08:47 PM
  #50
rick lambert
Can you hear the FP relay energizing the system? If the FPrelay is shot, it will take longer to fire, at least until the oil pressure reaches 4 lbs. BTW, check the wires going into the FP relay, the insulation shrinks and they can be bare and shorting.
Old Jun 30, 2006 | 08:57 PM
  #51
RRT vette's Avatar
RRT vette
I though about this Rick, but he says that there is pressure when the key is turned on. This would lead me to believe the relay is working energizing the pump. You know, otherwise the pressure will not show until the cranking begins (oil pressure switch).
Old Jun 30, 2006 | 09:41 PM
  #52
n1kki6's Avatar
n1kki6
Wouldnt the car be running funny? The pressure still seems to drop so I still dont have that fixed either.
By the way thanks a ton for the help so far.
Old Jun 30, 2006 | 10:13 PM
  #53
RRT vette's Avatar
RRT vette
Yes, it would. But these are two essential things needed to start an engine along with air flow. So, the pressure is doing the same as before? I would still like to see what the injectors ohm at , but I understand, that you don't have a ohm meter as of yet. Are you sure the only code you have is a current 72? If the spark and pigtail test work we will look elsewhere.
Old Jun 30, 2006 | 10:52 PM
  #54
n1kki6's Avatar
n1kki6
Buddy still hasn't stopped with his ohm meter. Injectors are pulsating and their is good spark.
New test. Last night I clamped the feed line at the rail, unclamped and pressure dropped. Tongight I clamped it at the tank, removed it pressure dropped again, could the problem be somewhere in the feed line not nessecarily something in the tank. Couldnt be something like a mas airflow sensor not getting a good reading when cold could it?
The only code I am getting is a c72 on module 1.
Old Jun 30, 2006 | 11:07 PM
  #55
n1kki6's Avatar
n1kki6
I've had enough fun for tonight, I am going to leave the pressure guage on over night and see what it reads in the morning.
Old Jun 30, 2006 | 11:10 PM
  #56
RRT vette's Avatar
RRT vette
If you are getting spark and you know the injectors are getting signal for the PCM, I would check the ohms on the injectors to see if they are working properly. Even though they don't leak and there is pressure, doesn't mean the coils are good. Make sure that when you turn the key to the on position (not cranking), the fuel rail is primed with at least 40 psi. If not, then I would suspect the fuel pump relay. Come to think of it, on a LT1 the fuel pressure reads mid 40's with the vacuum on and low 50's with the vaccum removed, when engine running. The FPR controls the pressure delivered and would be at fault with a diaphram rupture which you would see with gas in the vacuum line.
Old Jul 1, 2006 | 10:44 AM
  #57
rick lambert
BUT...what I think I'm hearing is when he turns the key on pressure is 40#, he clamps off the feed line and pressure holds. That in my mind eliminates leaky injectors (not say the coils couldn't be bad) and also eliminates the regulator. But, when he unclamps the feed line pressure drops..how much? because that to me indicates a leaky check valve or pulsator.
To Problems starting lately
Old Jul 1, 2006 | 10:56 AM
  #58
n1kki6's Avatar
n1kki6
Car fired right up this morning. I think it might be fixed I think the pressure gauge was leaking because when I came out this morning the pressure gauge hose was cracked open where it has to bend a bit for the egr valve.
Old Jul 1, 2006 | 11:29 AM
  #59
rick lambert
need to replace the hose.
Old Jul 1, 2006 | 11:33 AM
  #60
RRT vette's Avatar
RRT vette
Exactly, this would eleminate leaky injectors and FPR. Pressure would bleed down if either were leaking. The coil of the injector is where the signal is sent to determine how fuel to give...and comes from the PCM. If it still bleeds down after unpinching the feed line there is still a problem form the FPR back to the tank. You can try to just pressurize the system without pinching anything and count the minutes and how much pressure leaked down per minute.
