Problems starting lately
Old Jun 28, 2006 | 10:30 PM
n1kki6's Avatar
n1kki6
Default Problems starting lately
As of the last week I have noticed if the car sits for a few hours when I try to start it again it cranks for quite a bit longer before firing, where before it used to fire right away.
If the car only sits for say a half hour instead of a few hours it fires right up.
When the problem does happen sometimes right after it fires the rpm's will drop low for a second and then rebound and runs fine after that.
Any ideas what could cause this? Leaky injector(s) maybe?
Old Jun 28, 2006 | 10:39 PM
MikeC4's Avatar
MikeC4
I was thinking what you said, leaky injector(s). First thing to do is put on a fuel pressure gauge, ignition on to prime the fule rails, ignition off, and see if you observe noticable pressure bleed down in a short amount of time.
Old Jun 28, 2006 | 10:50 PM
RRT vette's Avatar
RRT vette
N1kki6, I followed the thread a few weeks/months back about the bad gas thing. Did you end up replacing the injectors or just cleaning them? From what we discussed I figure you know how to test the fuel system. A possibility it could be leaky injectors.
Old Jun 28, 2006 | 10:57 PM
n1kki6's Avatar
n1kki6
Didn't end up doing the injectors, just used some techron in the gas.
Must be a leaky injector. Upon clicking the key over I get 31 psi and within 5 minutes it dropped to 20 psi.
Old Jun 28, 2006 | 11:01 PM
MikeC4's Avatar
MikeC4
have you checked your FPR?
Old Jun 28, 2006 | 11:03 PM
n1kki6's Avatar
n1kki6
Nope, How can I test it?
Old Jun 28, 2006 | 11:19 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
It's just God getting you back for what it says under your avatar.....
There's a good tech tip on fuel system diagnosis, very easy to do. I'd have posted the link but I'm too lazy, drunk and tired.
Old Jun 28, 2006 | 11:36 PM
n1kki6's Avatar
n1kki6
Found the tech tip
... Here are the sure fail tests for the fuel system to save you time and money.. Take a fuel pressure gauge attach it to the schraeder valve.. turn the key on and off a few time to build up the pressure in the system... If you are having starting trouble the pressure will probably drop as soon as it hits 38 or 40 and the pump turns off it will probably leak back to zero within a few minutes. Ok now right after you prime the system pinch off the return line near the tank if the pressure drop stops it is a bad fuel pressure regulator.... Next pinch off the feed line if the pressure holds then the leak is before the point where you pinched the line IE fuel pump check valve..hole in the metal line on the sending unit caused by it rubbing on the inside of the tank you should visibly be able to see this if you pull the pump and the sending unit...(this was my problem) or the pulse dampener which is the piece between the pump and metal line on the sending unit.. the diphragm tears.. and last if you pinch both the feed and return line near the tank and the leak down of the pressure continues then a fuel injector is your problem.. This is the GM test.. saves time and money..
Old Jun 29, 2006 | 12:39 AM
n1kki6's Avatar
n1kki6
So is the FPR in the tank? Also are the stock injectors 22lb in a 94'?
Old Jun 29, 2006 | 07:25 AM
Corvette Kid
The regulator's at the rear of the intake manifold. The return fuel line comes out of it, that's the smaller of the two lines. Your injectors are 24# in a '94.
Old Jun 29, 2006 | 09:36 AM
n1kki6's Avatar
n1kki6
I think I may have lucked out. Just by chance that my battery was going I threw the charger on early this morning, went to start it about 8 and it fired right up. I don't think its the alternator because I am still at 14.3 -14.5 volts while driving. I was kind of wondering this because if I have my hood open for even 10 minutes it doesn't seem the car wants to fire normal unless I have something thats slowly draining the battery as the car sits.
Old Jun 29, 2006 | 10:32 AM
RRT vette's Avatar
RRT vette
Attach the fuel pressure guage and turn the ignition on (don't crank). Observe the pressure and turn the key off. As you stated the pressure drops which could point to leaky injector(s), ruptured diaphram in FPR, check valve not holding, or pulsator leak. For the FPR take the vacuum of and look for signs of gas. For injectors you will need to pinch off the fuel return line at the tank and see if pressure falls. Check valve and pulsator are in tank. More likely one or more of the injectors are not holding pressure. They are very easy to change on a LT1 compared to a L98. You can also remove the fuel rail assembly bolts and pull up the injectors still attached to the fuel rail and the fuel lines will have some slack so that you can hold the injectors above the holes and pressurize the system and visually check for leaks in the injectors. You can also ohm the injectors one by one using a ohm meter and touch the injector terminal with the black and red leads to get the reading and should be around 16 ohm. This just tests the resistance of the injectors and bad resistance can mean poor operation.
Old Jun 29, 2006 | 10:39 AM
n1kki6's Avatar
n1kki6
Yeah, their is still that, i brain farted. Too early.
To test the injectors I shouldnt pinch both lines like the tech tip said, or doesnt it matter.
Old Jun 29, 2006 | 10:46 AM
n1kki6's Avatar
n1kki6
Just went out and checked the FPR and their were no signs of gas.
Old Jun 29, 2006 | 10:50 AM
RRT vette's Avatar
RRT vette
I would just pinch off the return line.
Old Jun 29, 2006 | 10:52 AM
n1kki6's Avatar
n1kki6
How long should the pressure normally hold?
Old Jun 29, 2006 | 10:55 AM
n1kki6's Avatar
n1kki6
Also before I started having this problem upon clicking the key foward I would be in the upper 30's, now its at about 30, would this leak also cause my pressure to be down right away. I will check the pressure at idle on my lunch break.
To Problems starting lately
RRT vette's Avatar
RRT vette
Pressure in the fuel rail should hold for a while. Say 5 psi drop in 30 minutes or pressure should still be at 10 psi after 24 hrs.
Old Jun 29, 2006 | 10:59 AM
RRT vette's Avatar
RRT vette
For a LT1 the normal pressure run in the low to upper 40's. If pressure is not there I would check for obstructions in the feed fuel line, (fuel filter, clogged fuel pump sock, or leaks in the fuel line/smells of raw gas or evidence of gas under car on the pass side). A faulty fuel pump might work but not produce the pressure needed. From the bad gas thread, the sock might be clogged with gunk/trash. It is located on the bottom of the fuel pump. And to confirm the LT1 stock injector size is 24lbs.
Old Jun 29, 2006 | 11:05 AM
n1kki6's Avatar
n1kki6
The fuel pump I can pull out by simply unscrewing the plastic under the fuel door correct? Should I make sure to pull a fuse or anything before doing this.
