700R4 Question
Old Jun 29, 2006 | 03:39 PM
JasenZ51's Avatar
JasenZ51
Default 700R4 Question
Will a 700 R4 out of a Third Gen Firebird fit into my C4?
I have heard tail housings may be different, but thats an easy fix???
Old Jun 29, 2006 | 04:07 PM
Fubar569's Avatar
Fubar569
physically? yes
tailshafts are vastly different. you must use your old one
governors are different
servo is different
only the vette 700R will allow WOT in 4th gear. this is again an easy fix to swap in the vette parts
so to answer your question now in a short version...
yes it will fit, but they are still vastly different
Old Jun 29, 2006 | 06:09 PM
JasenZ51's Avatar
JasenZ51
Originally Posted by Fubar569
physically? yes
servo is different
Thanks for the reply. This is a rebuilt tranny that has all the Vette parts inside it. So basically all i need to do is swap tail shafts? Are all the electronics the same??
Old Jun 29, 2006 | 06:14 PM
Pete K's Avatar
Pete K
The tail shaft is 3/4 inch longer in a non vette trans. The tail housing is simple to swap. The tail shaft is not. The electronics are not the same. GM used approx 15 different wiring arrangements regarding the lock up.
Old Jun 29, 2006 | 07:17 PM
jeffyc's Avatar
jeffyc
good post pete
i was just about to say the same
Old Jun 30, 2006 | 03:47 PM
JasenZ51's Avatar
JasenZ51
If I have both trannys can i swap over the parts? Or is this going to be a nightmare to do? Has anyone on this board done this before?
Old Jun 30, 2006 | 04:13 PM
circlegroup's Avatar
circlegroup
I have just finished putting a 90 comaro 700R4 into my 90 corvette with no issues. Swapped the tail housings and the speedo gear. Peice of cake. Just check your yoke in the rear tail housing to see if it fits up tight and you will be good to go. Don't know much about firebirds.
Old Jun 30, 2006 | 04:18 PM
Pete K's Avatar
Pete K
The entire transmission must be disassembled to reach the c clip that holds the output shaft in. If you are comfortable tearing down the unit, no big deal. If you have never been in an auto trans, you don't want to tear into a 700r4 for your 1st time. Depending on the year of the trans, lock up normally switches right over.
Old Jul 3, 2006 | 03:38 PM
JasenZ51's Avatar
JasenZ51
Why does the Tail Shaft need to be swapped?
Old Jul 3, 2006 | 03:43 PM
GeosFun's Avatar
GeosFun
I do not know what years you are talking about. I had an '87 GTA and had the 700R rebult. The tranny guy said the pre-1988 700's cannot be built as strongly as later years.:o
Old Jul 3, 2006 | 04:09 PM
Pete K's Avatar
Pete K
The vette tailshaft is 3/4 of an inch shorter than the f-body. Some guys claim that it will work and not bottom out in the vette yoke. On the 3 that I have attempted, it has always NOT worked. Also vette uses a different hole for the drive (speedo) gear in the tailshaft. Remember to move it or it will chew up in the first couple of miles.
Old Jul 3, 2006 | 04:10 PM
Pete K's Avatar
Pete K
He is mistaken. It sometimes is not cost effective to do it, but can be done.
To 700R4 Question
