ZF Question
Old Aug 31, 2001 | 10:11 AM
Frank C's Avatar
Frank C
Default ZF Question
I was under the impression that there were two ZF's. An early (90-93) and a late (94-96). The later not being as strong do to a redesign to quiet it down. Last night I was informed that there were indeed two but not as I thought. This chap stated that all small block ZF's were the same and that the one for the ZR1 was different. Anybody know for sure? Thanks, Frank
Old Aug 31, 2001 | 10:46 AM
Scoob's Avatar
Scoob
Default Re: ZF Question (Frank C)
ZF 6-speeds began in '89.
And while I can't confirm this I seem to remember that the earlier ZFs (perhaps up to '92?) are the more robust ones.
I also don't think there is any difference between a regular ZF and the one's they put in the ZR1 but again, I'm not 100% sure.
Of course, I could be completely wrong. ;)
Old Aug 31, 2001 | 10:59 AM
1991Z07's Avatar
1991Z07
There are, indeed, 4 different designs for the ZF6. I'm not sure on when they made the change, but there is a difference. The internals are identical between the ZR1 ZF's and the standard ZF's.
L98/LT1 Early production-'90 to about '92 - Square-cut gears. Noisey and stronger.
ZR1 Early production thru about '92 - Same square-cut gears. Shorter input shaft.
LT1/LT4 Late Production '93 - '96 Change of the angles on gears to quiet down the growl - not as strong.
ZR1 Late production '93 thru final production - same gears as above but with shorter input shaft.
[Modified by Joe90, 9:00 AM 8/31/2001]
Old Aug 31, 2001 | 11:33 AM
Scoob's Avatar
Scoob
Default Re: ZF Question (Joe90)
Cool. Thanks.
So I've got a strong but noisy ZF.
Old Aug 31, 2001 | 11:40 AM
Frank C's Avatar
Frank C
Default Re: ZF Question (Scott 89)
Thanks Joe & Scott....Frank
Old Aug 31, 2001 | 02:11 PM
tommelton's Avatar
tommelton
Actually I was told the ZR1 had the l o n g e r input shaft.
Tom Melton
82 CE
86 Z51 Coupe with ZF6 conversion in the works
To ZF Question
