Headers vs. Superram
Old Aug 31, 2001 | 10:31 AM
Cratzy's Avatar
Cratzy
Default Headers vs. Superram
I am planning on building a 383, but I have to save up some money first.
I was thinking of buying headers to start with, cause I was thinking that I will need them later anyway. But maybe I should start with a Superram. It is the same $$
What do you think?
:seeya
Old Aug 31, 2001 | 10:46 AM
89vette's Avatar
89vette
Default Re: Headers vs. Superram (Cratzy)
The Super Ram is not the same money. Its more. You need the base and the SR. The base is $459.00 and the Super Ram is $759.00. Headers are about $750.00 from TPIS. Its a tough call. I'd say go for the the SR.
Jason
Old Aug 31, 2001 | 10:47 AM
-=Jeff=-'s Avatar
-=Jeff=-
Headers.. First
if you get the super ram you should get the base at the sametime. But also you should consider what you want from the 383.. headers will work for both.. but when you go the 383 will you want a motor that has power inthe upper RPMs? or similar to the stock set-up?
Old Aug 31, 2001 | 01:13 PM
Aaron's 87's Avatar
Aaron's 87
Default Re: Headers vs. Superram (-=Jeff=-)
Headers - The SR can't breathe more if the stock exhaust can't get the air out.
Old Aug 31, 2001 | 01:27 PM
miker61588's Avatar
miker61588
Default Re: Headers vs. Superram (Aaron's 87)
go with the superram first cause you want the engine together not apart..
get the ceramic coated headers from demonsports i paid 550 there long tube and there not hard to install. there meant for the car cause they fit really easy
easiest header job yove done :D
Old Aug 31, 2001 | 01:55 PM
Mojo's Avatar
Mojo
Default Re: Headers vs. Superram (miker61588)
I have the HOK2149 Hooker Super Comps. They were about $450 through summit. Easy install, and they're quality!
Old Aug 31, 2001 | 02:25 PM
J Z06's Avatar
J Z06
Default Re: Headers vs. Superram (Mojo)
Go with Headers FIRST. Then, once you do the SR/383 you'll be set to go. 1"5/8's or 1"3/4?
[Modified by JD 90 383, 12:26 PM 8/31/2001]
Old Sep 3, 2001 | 05:13 AM
Cratzy's Avatar
Cratzy
Default Re: Headers vs. Superram (JD 90 383)
I think I will go with headers first. But which one should I get? And in what size? I was planning on Lingenfelter but I have heard through the Forum that they are a PITA to install, so now I am thinking of TPIS. :cheers:
Old Sep 3, 2001 | 08:34 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Headers first.
Old Sep 3, 2001 | 10:04 AM
Aaron's 87's Avatar
Aaron's 87
If you're making a stout 383, 1 3/4" headers will work. People seem to like the Hookers.
Old Sep 4, 2001 | 11:22 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Where is the O2 sensor located on the Hookers?
Is it in the collector or one of the exhaust pipes before the collector?
To Headers vs. Superram
