92 Brake Problems continued...
Bled all four wheels.
The pedal problem still exists. The calipers are all dry - so I don't think they are leaking.
The only cheap thing left is to bleed the ABS unit behind the driver's seat. Beyond that - the last part to replace is the ABS unit itself. That's an $1100 rebuilt part. It doesn't appear to be leaking anywhere..
I hate throwing parts at problems...
Any suggestions?
did you check the valve array in the ABS bin (behind the drivers seat) for any sign of leakage?
What is the pedal like? hard or soft (engine running)?
Did you bench bleed the new master? If not, it will be nothing short of a bitch to bleed.
Recently, the brakes have started to behave strangly. The pedal is suddenly very soft. The travel is longer as well. The pedal won't pump up. The brakes still work but worse than before (which was not so hot to start with)
In the last year I've replaced:
Master cylinder (with one from EBAY...questionable)
vacuum booster (with the metal one from that hotrod website)
brake fluid
pads (Hawk HPS)
rotors (slotted)
I've bled the system twice. There is no fluid leaks that I have found.
The change in pedal feel was very sudden - like something snapped. Any idea where to look first?
The pedal has very recently changed to a huge amount of travel, and very little resistance. The pedal doesn't push up against my feet. This all started after I slammed on my brakes the other day. I pressed hard against the pedal - ever since then it feels like something popped...
So, I bled the brakes again - no change.
So, I figured it wat the master cylinder - bought a replacement, did the bench bleed, installed it and bled the whole system again. - no change.
I've gone through the big container of valvolene synthetic DOT4 brake fluid (the quart size bottle) through the system. I didn't notice any problems with the rubber brake lines.. no bulging, leaks, etc.
What I meant about the dry calipers: Calipers fail by sticking or by leaking. Sticking would give a hard pedal (which I don't have) and leaking would be a mess - which it isn't.
The pedal travel is just weird. It goes almost all the way to the floor with very little effort.
I opened the hatch to the ABS module behind the driver's seat - and it appears dry. I'm not actually losing ang brake fluid from the master - the pedal feel is just way different and the car doesn't stop very well.
Has anyone ever had an ABS module fail?
I am thinking you got a bad replacement master... Goto NAPA.
Have you physically inspected the brake pedal mechanism? It could be a mechanical failure... the pedal bracket is failing... who knows...
It happened to me, purchased a NEW one and Viola, I have brakes.
When you open up the bleeders and hit the brake pedal, you should get wet. If the calipers are dry, you have a master cylinder problem.
Pedal travel continues to be about 3" as measured from the steering wheel.
Any other thoughts?
