Idle Problems
Old Jul 2, 2006 | 03:05 AM
LACYLADY's Avatar
LACYLADY
Navigator
Default Idle Problems
Hello ppl i need help again pls.....my 87 Vert starts immediately when cold and if i drive it for 1/2 hour, stop go into a store, come out a couple minutes later she starts great and idles fine. However if i let her sit 30 to 60 minutes and start her up, she rolls for about 3 seconds to start it, then she idles between 9 -10. WHAT COULD CAUSE THIS ????? Any suggestions? thanks in advance.......Lacy :-)
Old Jul 2, 2006 | 03:52 AM
86PACER's Avatar
86PACER
Does the Service Engine light come on? I'd check the the TPS voltage when it's idling high and when it's idling normal (upper two wires) and compare. Specs are .54volt at idle. A bad TPS will cause this.
Old Jul 2, 2006 | 02:56 PM
LACYLADY's Avatar
LACYLADY
Navigator
No the engine light was coming on before and we changed the relays, and head gaskets, clean injectors and few other things, now the engine light does not come on anymore. What is this TBS you referred too???............thanking you in advance..........Lacy :-)
Old Jul 2, 2006 | 05:12 PM
86PACER's Avatar
86PACER
TPS is the Throttle Position Sensor. It's mounted on the side of the throttle body and has a 3 wire connector on it.
To Idle Problems
