Dreaded Optispark
Old Jul 3, 2006 | 06:28 PM
RetroTA's Avatar
RetroTA
Default Dreaded Optispark
My 93 wont start! Checked fuel press (held 39 lbs for over 10 mins.), ohmed fuel injectors(13+all), Changed fuel filter, even syphoned gas and replaced with fresh, getting spark at all cylinders, will not fire even with either sprayed into air intake. Ive ruled out a fuel problem. My question is..........If the optispark goes bad, Would I still be getting spark at all cylinders and shouldint it at least start? I know it can effect performance but I figure it should at least start. Also could a bad Opti effect timing at all?
Old Jul 3, 2006 | 06:58 PM
bogus's Avatar
bogus
check, at the very least, the coil wire.
you really need the Factory Service Manual to properly debug this problem. www.helminc.com.
Old Jul 3, 2006 | 10:24 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
see my reply to your other post.
Just remember, the "dreaded" opti is a distributor like any other and will suffer the same things a normal one will, just somethings more than others.
Old Jul 3, 2006 | 11:36 PM
MikeC4's Avatar
MikeC4
First thing you absolutely need to do first is dump your error codes. This will set you on the right path to diagnosis. This is easy to do yourself, or take to Autozone for free error check.
Yes the Opti can screw up timing if the optical sensor or shutter wheel are defective. Is your Opti original? How many plugs did you test for spark?
How fast did your fuel pressure drop after 10 minutes? It should hold for many hours, and only drop very very slowly.
Also, is eyther the same as starting fluid(ie Is it highly combustable)?
Old Jul 4, 2006 | 04:31 AM
RetroTA's Avatar
RetroTA
http://forums.corvetteforum.com/show....php?t=1435464
To Dreaded Optispark
