Front brakes still chirping!!
Old Jul 4, 2006 | 11:29 AM
timvette's Avatar
timvette
Default Front brakes still chirping!!
OK. New pads (Bendix semi-metallic). Rotors are fine (nice, smooth, only 51Kmiles). My mechanic knows what he's doing, did the brake greasing at edges of pads. Checked the wear sensors, etc. Mechanic hand turned the wheels and could hear no chirping/squeaking (even after I took it back). Brakes feel great, stop strong. These are the fronts that were replaced. The rears are almost new (checked everything back there too). The chirping seems brake related to me because the sound dims when braking is applied. It did this last week before the front pads were changed, so now I am really puzzled. The sound is non existent when the car is cold and only driven for the first few miles, then once everything gets warmed up the sound rears its ugly head. Please help anyone. My vette is a '95 LT1 w/ 51,000 miles.
Old Jul 4, 2006 | 01:33 PM
CharlieLed's Avatar
CharlieLed
Are you sure it's the brakes and not the hub bearing?
Old Jul 4, 2006 | 01:51 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My experience has been to ensure the pads "float" free when installed in the calipers.
Sometimes a little trimming with a file is required on the backing plate to relieve any binding with the caliper.
Old Jul 4, 2006 | 10:14 PM
timvette's Avatar
timvette
Thanks, I'll try this.
Old Jul 4, 2006 | 10:16 PM
timvette's Avatar
timvette
I wouldn't know. I'll check it out. Would the sound change like it does when I apply the brakes? Didn't think bearings would be affected by this. (??)
Old Jul 5, 2006 | 01:07 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Did the mechanic turn the rotors?Even if they arent warped,any glazing,bluish color on them?Checked both sides?
Anytime I do front pads and dont turn the rotors,I clean then scuff the rotors with sand paper to a non directional finish.Then I wash them down good with brake kleen before install.This always seems to do the trick to prevent any noise.I dont know if thats whats wrong with your set up,but its always worked for me.The pads need a good clean surface to bite into when they get broken in.If theres any glazing or hot spots,blue/blackish tarnish on the smooth rotors you have,it can cause noise with new pads.
Just a suggestion,may not be whats wrong.
Old Jul 5, 2006 | 08:10 AM
silver86's Avatar
silver86
I have the same problem on my 86. I installed new pads and rotors at all corners. Now the first few minutes are fine. But when things get warmed up....I hate it. One thing I did notice is that the old pads were installed with a set of shims. I've never installed a shim kit for the pads, but I have seen them advertised in a few of the 'vette websites. When I get the blower done, I'm trying some of these out because I can't stand this noise!
Old Jul 5, 2006 | 01:52 PM
timvette's Avatar
timvette
I am dropping it off at the dealership tommorrow. I will have them check the rotors. The rotors were not turned, as the mechanic said they were fine. So, I'll have the dealership check them out and try the above tactics you mentioned. I'll also ask about using shims too. I hate going to dealerships, but they have more of a chance at seeing these types of problems before, so I'll give them a try.
Old Jul 5, 2006 | 03:46 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Chirping, or a high pitched squeal?
Apply this to the steel side of your brake shoes:
(also comes in spray can)
and douche your rotors and pads good with this:
Old Jul 5, 2006 | 06:40 PM
timvette's Avatar
timvette
CentralCoaster,
It is more like a high pitched squeal than chirping noise. I hope this is the culprit and nothing expensive. I will purchase the two items you suggested. Thanks for your help. Oh yeah, the "steel side" being the side that has contact with the rotors or the side that has contact with the calipers? I know, a dumb question but want to make sure I get this right.
Old Jul 6, 2006 | 12:05 AM
Aggravated4life
Originally Posted by timvette
CentralCoaster,
No,never a dumb question...always ask anything,no matter what..no one knows everything,and the guys are here to help....the steel side is the back metal plate the pads are glued,or riveted onto.You apply some in the back of the pads,and when the stuff dries,it helps keeps the pads in place inside the caliper,or piston and not move.You had the right idea...common sense came into play for ya,but never feel theres a dumb questions.There may be a few people on here who may criticize that theres a dumb question,but they forget this stuff isnt what every member is about.
The only dumb question is the one not asked,and a person assuming he/she knows it all anyways.You start somewhere and build your knowledge..we all did and I never forget that.
Old Jul 6, 2006 | 01:53 AM
JrRifleCoach
CentralCoaster,
Did you or the "Mech" bed the pads in? If not, between not turning the rotors and not bedding them in, its no wonder the brakes are squeeling.
Old Jul 6, 2006 | 03:01 AM
CentralCoaster
It's actually pretty common for dumb people to spray it on the friction surface, because they never asked the "dumb question" you did. Coating the rotors with oil would stop the squeal too...
In all seriousness, turning the rotors and bedding the pads is always a great idea. I'm not sure if it will affect the squeal, but they'll stop better.
To Front brakes still chirping!!
By Michael S. Palmer | 2026-06-03 11:00:24
