Summertime and the AC posts keep coming
The charging instructions in the GM Service Manual make it sound daunting (e.g., the system should be evacuated before recharging, etc.) However, I keep seeing these simple kits advertised--are they safe and reletively foolproof?
Thanks,
Doug
Here's how the '95 works - A/C request travels over a serial data line from the Dash Controls to the Programmer. Programmer sends the signal onto the PCM which then drives (grounds) the compressor relay as long as the pressure switch signal (on the high side line) is somewhere around .8 volts (which is about 80 psi and with it sitting still and fully charged, it should have that #). Compressor will engage as long as the low pressure switch contacts are closed and that switch closes at 50 psi (again it should have that). You could just try a new relay, but I'd troubleshoot first by checking the low pressure switch - put a meter across it and verify continuity with the engine up to temp. Then, with that verified and a/c requested, I'd wriggle around that connector and maybe even remove it and plug it back in to see if the clutch engages. If the contacts read open - replace the switch. And if monkeying with the connector gets it to work, you'll probably need a new switch and a connector. If all that checks out, a bi-directional scanner will emulate the control panel and send specific control panel requests to the Programmer. If it all works, the data lines can be ohmed out, but it's more probable that the Dash Controls are on the fritz. If the scanner generates the same response, you may need a new Programmer, but I would also want to see whether or not there's a "Yes" on the Scanner Display when you request a/c and the voltage signal and pressure readout from the Pressure Switch to rule out the PCM. If you mechanic doesn't have the right scanner, I'd see what a dealer wants to hook one up - can't imagine that it's more than an hour for diagnostics.
My local guy (not a gm dealer) said the type of behavior I was experiencing was a frequent problem for this ac system (and typical of an ac programmer problem) and he suggested that using the ac more would help (I rarely use the ac and it probably had been on only once or twice over the last 9 months until the latest heat wave here).
Running it has nothing to do with it - though using it every now and then does prolong the life of the shaft seal which is somewhat problematic on the Nippondenso compressor. I'm pretty sure your problem has to do with electrons. A scan will tell you a lot and I can't imagine it costing more than 85 Bucks - assuming shop labor is similar to what it is in San Diego.
