SYS Help
Old Jul 4, 2006 | 01:50 PM
tennis1's Avatar
tennis1
Default SYS Help
Just had the ECM changed by dealer. Drove home, no problem. Next day tried to start car-ESR light comes on, the security light on the dash flashes, and where normally you see the oil temp and engine temp values on the digital portion of the dash, "SYS" flashes consecutively wit the security flash- Now what?
Car just cranks and won't start.
'92 auto.
Old Jul 4, 2006 | 02:02 PM
MikeC4's Avatar
MikeC4
sounds like low battery voltage indicator. How far down does the dash voltage gauge dip while you are cranking. Since they disconnected your battery while putting in new ECM, check to make sure that they fastened it securely......Check both Pos. and Neg. posts
Old Jul 4, 2006 | 06:40 PM
tennis1's Avatar
tennis1
Thanks will try it. Hope you are right since I have a new battery and new alt recently installed.
Old Jul 4, 2006 | 07:11 PM
MikeC4's Avatar
MikeC4
I have heard many stories of people buying "bad" new alternators....so you may want to have it checked just to be sure...
Good Luck....
Old Jul 4, 2006 | 08:41 PM
jabez's Avatar
jabez
Maybe you got a bad ECM.
Old Jul 5, 2006 | 12:00 AM
tennis1's Avatar
tennis1
My guess is the ECM is bad(again). Will contact dealer tomorrow. Unfortunately it will need to be towed in.
Old Jul 5, 2006 | 10:27 PM
tennis1's Avatar
tennis1
Default Bad brain
Yup, had the car towed to the local dealer and sure enough they called me a few hours later and told me the ECM was bad (again).
Good thing I bought the Delco factory rebuilt one ($425.00) vs the aftermarket $95.00 module (which probably is the same thing, anyway).
I know Delco has some financial troubles, and you wonder why.
Now I am again on a wait list for another ECM.
To SYS Help
