Iac
Old Jul 5, 2006 | 01:05 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Iac
I replaced my IAC, now my car idles around 850 rpm.
I did procedure to reset the IAC, start the car andd turn off after 5 secs and then wait 10 and start the car again and it did not reset to normal.
Did I mess up something or not do it right?
It is a a4.
Old Jul 5, 2006 | 01:11 PM
bogus's Avatar
bogus
there is a pedal press step in there somewhere...
Old Jul 5, 2006 | 01:15 PM
rick lambert's Avatar
rick lambert
Go drive it 30 miles.
Old Jul 5, 2006 | 01:40 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Forgot to mention, in the 1st step, I did slightly press the gas.
Drove it 25 miles to work, still idles high.
Does it matter if the engine is cold or hot when trying to reset the IAC?
Thanks!!
Old Jul 5, 2006 | 01:52 PM
CFI-EFI's Avatar
CFI-EFI
Did you use the correct gasket with the new IAC? A little extra air could explain a few extra rpms.
RACE ON!!!
Old Jul 5, 2006 | 02:16 PM
mseven's Avatar
mseven
Originally Posted by Randy93
Does it matter if the engine is cold or hot when trying to reset the IAC?Thanks!!
I do it fully warmed up (in closed loop)
Old Jul 5, 2006 | 02:45 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Yes, I used the gasket.
I did it with the engine cold, I will try it hot.
Thanks everyone!!
Old Jul 6, 2006 | 09:34 AM
Vetracr's Avatar
Vetracr
It doesn't sound like you reset the minimum air setting.
Turn on ignition
Wait 10 seconds and disconnect IAC connector
Start engine
Adjust Idle screw to minimum idle speed (550rpm)
Turn off engine
Reconnect IAC
Start engine.
Larry
Old Jul 6, 2006 | 11:50 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks, Larry!!!
Old Jul 6, 2006 | 01:00 PM
Steel Breeze's Avatar
Steel Breeze
Turn on ignition
Start engine
Turn off engine
Reconnect IAC
Start engine.
Larry
Or you have a vacuum leak, Or like CFI-EFI has mentioned. If the gasket on the IAC is to thick, it will get extra air by not closing the valve properly. That is just like a vacuum leak. The two walk hand in hand...
To Iac
