Sys Light Flashes
Old Jul 5, 2006 | 06:27 PM
SMAR1477's Avatar
SMAR1477
Default Sys Light Flashes
96 Lt1 Vette. Sys Flashes In The Instrument Cluster. Usually Does It At Night. Flashes Three Time The Waits A Bit And Does It Agian. Does It Randomly Nothing I Do Makes It Do It Are Not Do It? Any Ideas? no problems with anything i am aware off. sys just flashes when it decides it wants to mostly at night. battery is good car cranks fine
Old Jul 5, 2006 | 06:46 PM
STL94LT1's Avatar
STL94LT1
Sounds like a low battery charge.
Old Jul 5, 2006 | 08:27 PM
TankerVette's Avatar
TankerVette
aftermarket radio install?
Old Jul 5, 2006 | 08:28 PM
MikeC4's Avatar
MikeC4
...your good battery may not be as good as you think, or your alternator may be going out. Have your alt. tested.
Old Jul 6, 2006 | 12:15 AM
SMAR1477's Avatar
SMAR1477
i do have a aftermarket radio. battery and alternator has been checked and there good. never have a problem starting. stays AT 14V ON THE GUAGE ALL THE TIME PRETTY MUCH.
Old Jul 6, 2006 | 03:52 PM
TankerVette
aftermarket radios can cause the issue you speak of...
see:
http://forums.corvetteforum.com/showthread.php?t=941281
good luck
To Sys Light Flashes
