From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The C4 has the 4 3/4" pattern that most five lug Chevys have had since the 50s. Whether those wheels will fit is based on many things, no pat answer there, such as what you consider "fit", offset, etc.
I was told there was NO WAY a 15" rim would fit on the car. 16" minimum. I Have a few sets a drag radials(15") so I was gunna pick up some rims but I don`t know if I can do it.
Another guy on this forum told me a while back that he had 15`s all the way around, skinnies up front and 15x10 out back.
