Interesting coolant leak....
Old Jul 7, 2006 | 02:04 PM
silver86's Avatar
silver86
Default Interesting coolant leak....
So I'm changing my runners back to the stockers, and I see coolant weeping out of the front passenger lower runner bolt hole. I didn't leak when the runner was mounted, just when I removed the bolt and moved the plenum around (I hate disconnecting those TB coolant lines!). No coolant in the oil, no coolant leaks on the outside of the motor, no smoke in the exhaust...so I was wondering if this is a common problem with the TPIS manifold of if something more dire was happening here. I already re-installed the bolt with the factory runners and a little sealant tape...still no leaks after resetting the IAC. So I guess it's good to go. Any oposing views?
