horns died
Old Jul 9, 2006 | 01:00 PM
gixxr's Avatar
gixxr
Default horns died
before I start going on my search for new horns anyone got any advice on replacement, 93 coupe
Old Jul 9, 2006 | 01:08 PM
RRT vette's Avatar
RRT vette
http://www.ecklers.com/product.asp?p...dept%5Fid=1122
http://www.madvet.com/shop?frame=3.1078
http://www.parts123.com/parts123/yb.dll?parta~partsort
http://www.autozone.com/servlet/UiBr...%7ENONE%7C%7EB
or a vette junk yard will have some.
F note
Old Jul 9, 2006 | 01:15 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Before you replace the horns make sure the problem isn't a blown fuse or bad contacts in the circuit. My horns work but only with the left horn button, the right one is dead. And before you start fooling around with the horn buttons or any part of the steering wheel pull the fuse for the air bags.
Old Jul 9, 2006 | 01:27 PM
gixxr's Avatar
gixxr
Don't think so, both horn buttons work , when I hit them the volt gauge bounces also the right one went first now the left one just blew, get it blew hahahaha
Old Jul 9, 2006 | 04:21 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
If the volt gauge moved, I think there is definitely something shorting out.
My horns don't work, the actual horns blow, but the horn switch is bad. They go bad on these cars pretty easy since they are just cheap plastic.
Old Jul 9, 2006 | 10:31 PM
gixxr's Avatar
gixxr
how can I check that
Old Jul 9, 2006 | 11:29 PM
Mr Mojo's Avatar
Mr Mojo
Not sure, mine was easy to diagnose, the horn blew till the fuse blew out. My buddy who is a GM Tech said right off it was the switch. The button gets stuck in the "in" position and you could hear it crack when he manuevered it back in to the proper position.
To horns died
