More Exhaust Questions
Old Jul 9, 2006 | 07:39 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default More Exhaust Questions
If I decide to put on headers, 1990 L98, the exhaust goes into a "Y" pipe into the cat.
It seems to be a waste of time to go through putting on headers only to run a "Y" pipe into a cat.
So, I have questions.
1. To go straight dual, do I really need those high flow cats for $300 each, or since I'm going from one to two cats, will two standard ones work? That would essentially double the flow, right?
2. What's the tube for on the cat? Do I need to get another one with a tube
3. "X" pipe or "H" pipe to balance the pressure? Why?
Thanks, I'm sure you guys are sick of these questions. So thanks in advance.
Old Jul 9, 2006 | 07:53 PM
vader86's Avatar
vader86
I'd get two smaller cats from Random Tech if i went that way. You wont need two L98 main cats if thats what you mean, bullitt cats would be called for with duals. LT1 cats would work, since it all needs to be fabbed anyway.
Its the AIR tube from the pump, you should just delete the whole system if youre using headers, if you can in NJ.
X or H pipes reduce resonance and change the power curve slightly, similar to extending header collectors, they tend to bump the low end a bit.
Old Jul 9, 2006 | 09:04 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Be careful. Check with some cooler knowledgeable heads in NJ. You don't want to run afoul of inspections every two years or so. Maybe the best thing to do is check with a muffler shop for their advice re what's allowed. Then you can go the two smaller cats, y, X, H, pipes, etc. More research (check twice, cut once).
Old Jul 9, 2006 | 09:15 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yes, I'd definitely go with dual cats. If you don't, you wont have a true dual system. If it'd help, I've got two brand new 3" universal cats. They're not quite as small as bullet cats but not very big either. They'd easily fit just past the headers (next to the trans) on a manual car but not on an automatic. If you have an auto, they'd have to be located beyond the tranny. PM me if you're interested. I don't have too much in them and so I could let them go cheap. They also have air tubes on them which come blocked off but could be opened up if needed.
Old Jul 9, 2006 | 09:31 PM
jsup's Avatar
jsup
I have an auto. Is the exhaust hot enough to make a cat work beyond the trans?
WIll the bullet cats fit right off the headers on an auto?
I'd love to pick up a pair, if I could.
Are there cheaper ones than random tech? Is it worth the $300 per cat for the RTs? Seems like an awful lot. Are there any cheaper ones that will work?
Old Jul 10, 2006 | 05:50 AM
Eike's Avatar
Eike
I want to go for it, too. Should be all stainless ... what do you think of this one on ebay?
http://cgi.ebay.com/ebaymotors/ws/eB...m=130005120115
I think the air tubes can be welded on ...
Eike
Old Jul 10, 2006 | 09:34 AM
jsup's Avatar
jsup
Eike
hell, for $40 do these things work? Anyone know anything about it?
Old Jul 10, 2006 | 10:46 AM
jsup's Avatar
jsup
Eike
I called this guy. He seems to be pretty knowledgeable. Seems to know his stuff.
He has a set of cats for $110 each that he says are 4" in diameter.
Will a 4" diameter cat fit off the headers on an automatic? If they do, I think I found my cats.
Old Jul 10, 2006 | 11:56 AM
jsup's Avatar
jsup
Called TPIS.
He's telling me that headers with their "Y" pipe into a single cat is more effective than dual cats and an "X" pipe.
Comments?
Old Jul 10, 2006 | 01:50 PM
vader86's Avatar
vader86
I wouldnt listen to his opinion, do whatever you want to the car. It'll turn out good either way. If you choose good cats.
To More Exhaust Questions
