the tack does not work when you start the car the tack jumps up to 6 then back down the 0 i hooked my scaner up and it gives me the RPM any ideas thanks
I recently bought a '90 that had not been used much for it's age and initially had some erratic to inop tach problems. They never seemed to last long, so I never pursued it.
I had seen previous Tach problems entries on the Forum, so I thought I'd share. I'm sure you'll get lots of help on this but:
Problem Source Possibility: Tach Filter, which OEM is no longer available
Previous suggestions: disconnect it - Tachs seem to work fine without it.
But since it may have had a valuable purpose sources for after market:
Of course it could be your tach or connections etc, but you might want to check here first. I know if mine starts acting up, it will be the first thing I check.
