91 injector replacement
Old Jul 10, 2006 | 10:31 PM
rcr103's Avatar
rcr103
Default 91 injector replacement
Found a bad injector,replacing all,I am also replacing intake manifold gaskets,thermostat,belt tension pulley,egr valve.
While I have the intake off I want to port the runner tubes and match the intake to the tubes.
Question is should I also port and match the plenum to the tubes?
And can I use the old Plenum and manifold to tube gaskets,They look good?
Thanks for any help.
Randall
