timing and idle ?'s
Old Jul 11, 2006 | 04:11 PM
Bubba91's Avatar
Bubba91
Default timing and idle ?'s
I set my timing at 8*btdc w/ est disconnected, my tps is at .54, and my idle is at 650-675.
Is 650-675 too low?
Old Jul 11, 2006 | 10:46 PM
patsfan's Avatar
patsfan
From: Swanton VT 2000 Navy Blue Mettalic M6 / 1991 Auto - Steel Blue 68,500 R.I.P
Old Jul 12, 2006 | 12:21 AM
black_89_vette's Avatar
black_89_vette
Mine idles around 900 and I'm fine with that. Last time I tried it didn't want to get as low as the tech advice told me.
Perhaps I was doing something wrong? Anyways, I idle around 900 and am ok with it.
If you're ok with your idle, it's ok with me, heh.
Old Jul 12, 2006 | 11:41 AM
rick lambert's Avatar
rick lambert
Your idle if fine!
Old Jul 12, 2006 | 04:00 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
it should be good
Old Jul 12, 2006 | 04:04 PM
RRT vette's Avatar
RRT vette
On start up, mine idles around 1000 rpm. After a minute or two the idle comes down to 800 rpm or so, After I start driving the idle is at 675 RPM. Confirmed by scan. I think your where you need to be.
Old Jul 12, 2006 | 08:51 PM
CFI-EFI's Avatar
CFI-EFI
Is 650-675 too low?
Your idle speed is burned into your chip. Your nonadjustable TPS and advanced ignition timing won't change your idle speed unless they cause a condition outside of the range the IAC can compensate for.
RACE ON!!!
Old Jul 14, 2006 | 04:49 PM
Bubba91's Avatar
Bubba91
thanks to everyone
To timing and idle ?'s
