cut back plugs?
rssshen vette
You could get away with a slightly larger-than-factory gap, but what would be the point...?
Larry
code5coupe
Thanks rocco 16!!
I'll start with . 45 and go from there.
Thank
Thanks,Matt
with the Kid.From what I've read there's very little benefit and it comes at an RPM range where most of us don't go. One other thing, I heard awhile back ACDelco was going to market cut backs...wonder whatever became of that.
(Manufacturers of spark plugs aren't as stupid as we think they are.)
Larry
code5coupe
Larry
code5coupe
In your car why are you running the blue goo C114?
If you aren't above 11 to 1 compression just run regular fuel.
At most I would be running 106 the red.
Cut back plugs are for high compression engines putting out atleast 500 hp.
I run cut backs in my 86 but it jumps off the ground when it is Idleing.
Its around 700hp and I run C116 and C114,15 to 1 compression.
Cut backs just make it easier to fire the fuel which has a higher burn point.
Higher octain takes more heat to fire the cylinder than regular fuel.
At what point, does the "every little bit helps" come into play? Or are you guys saying there's zero gain?
Larry
code5coupe
Just like I've seen U-groove, split electrodes, multiple electrodes, halo plugs, and JCWhitney FireIgnitors from 40 years ago.
They are all gimmicks that have no actual value.
A spark plugs function, and therefor the spark plug itself, is so damn simple that the manufacturer HAS to do something to set their product apart from every other nearly-identical spark plug on the market.
Indexing? It may help, although I have my doubts.
Indexing is supposed to expose the spark to the incoming charge/intake valve.
Problem is, by the time the spark fires, the intake valve is closed and the intake charge is swirling around in a closed chamber that, in effect, has no valves (since they are all closed), just a compressed charge in a featureless chamber.
Cutting back plugs and indexing plugs will not hurt an engine's power output, but they don't enhance it enough to make it worth the effort, either.
My $.02
Larry
code5coupe
