Mixing octanes - do you know the formula?
Old Jul 11, 2006 | 11:03 PM
froggy47's Avatar
froggy47
Default Mixing octanes - do you know the formula?
It's high school math, I know, but I forgot, ok.
Let's say you mix 5 gal of 100 octane unleaded pump gas with 15 gal of 91 octane unleaded pump gas, what octane do you have in the tank?
or 2.5 gal 100 with 17.5 gal of 91, you get the drift?
TIA
Old Jul 11, 2006 | 11:58 PM
DougSilver's Avatar
DougSilver
I believe it is basically just the weighted average divided by the total number of gallons. So in your first example, 5 gallons times 100 plus 15 gallons times 91 equals 1865. Then 1865 divided by 20 gallons equals 93.25 octane. In the second example 2.5 gallons times 100 plus 17.5 gallons times 91 equals 1842.5. Then 1842.5 divided by 20 equals 92.125 octane.
Class dismissed.
Old Jul 12, 2006 | 12:03 AM
scorp508's Avatar
scorp508
It really is that easy. Many of the pumps you use mix the gas right at the pump like this.
[(Octane1 * Gallons_O1) + (Octane2 * Gallons_O2)]/Total_Gallons
Old Jul 12, 2006 | 12:06 PM
froggy47's Avatar
froggy47
Thanks guys.
Old Jul 12, 2006 | 02:29 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
here's another one: 9 gal. of 93 octane + 9 gal. of 89 octane = 18 gal. 91 octane. luckily that's all i have to remember.
Old Jul 12, 2006 | 02:46 PM
redrose's Avatar
redrose
i was manager of local gas station until a couple months ago...delivery manifests for mid-grade were often a mix of reg + super on the paperwork, just a linear relationship, as noted above
Old Jul 12, 2006 | 02:53 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Years ago (don't ask me how many) it went something like this:
5 gal. of 89 octane + 5 gal of 91 octane = 10 gal of 92 octane.
That hasn't been the case in awhile, so if you don't believe it, it's understandable.
Larry
code5coupe
Old Jul 12, 2006 | 03:25 PM
froggy47's Avatar
froggy47
Huh?
Are you saying mix unleaded with leaded? Back in the day when I guess you could do that?
Then I would perhaps believe anything is possible.
Remember when you could carry a little "sizer" thing that fit in the small unleaded hole but let you pump from the big leaded nozzle?
Old Jul 12, 2006 | 07:30 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
It's true. Used to be a time when you could mix some lower octane gas with mid range and actually get a higher octane at the pumps. When it ended, I don't know. But, there was a time....
Old Jul 12, 2006 | 07:34 PM
froggy47's Avatar
froggy47
OK guys, it's 2 against one, so if you say so.
I got some Sunoco 100 unlead today.
Old Jul 12, 2006 | 07:58 PM
CFI-EFI's Avatar
CFI-EFI
Larry
code5coupe
ABSOLUTELY!!!
Except as I remember it your answer of 92 is probably low. Back in the day, as low lead and unleaded gases were coming on line, the crappy no and low lead gases had to be much more highly refined than the leaded gases, just to have any octane at all. A mix of about 15 gallons of no lead with 5 gallons of premium could result in 15 gal of 87 + 5 gal of 92 = 20 gal of approx 98. It didn't take much of the lead from the leaded gas to drive the more highly refined, no lead gas, nuts.
RACE ON!!!
Old Jul 12, 2006 | 10:10 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
thats
Old Jul 12, 2006 | 10:19 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Originally Posted by froggy47
Huh?
Actually I remember when you didn't need a 'sizer' at all because all the gas was leaded and all the cars could use it.
But I guess I'm just showing my age.
Old Jul 12, 2006 | 10:59 PM
Hole-Shot's Avatar
Hole-Shot
What is your compression ratio?
Hi-octane fuel actually has a lower flash point than a lower octane fuel.
Old Jul 12, 2006 | 11:15 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Originally Posted by CFI-EFI
ABSOLUTELY!!!
RACE ON!!!
You're right. Now that I think about it, there was some formula that made it more/higher octane than anything you could buy at the pumps, even Sunoco 260 and (?)Gulf Super G (?) or was it Gulf Pride?
To Mixing octanes - do you know the formula?
